SOURCE: Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
SOURCE: what is the gas/oil mixture for poulan wild thing chain saw?
I have a manual for that saw that says the mix is 40:1- 3.2 oz. of oil to 1 gal of gas .
