Question about Panasonic Heating & Cooling
How do ifind the btu for my cz-10rt32p air con
    Problem Solver:
  • 11 Answers
Air Con Model Numbers normally have the capacity of the unit within the Model Number, but not always. It would look to me as if your unit was a 32,000 BTU unit, but I could be wrong. It should say it on the label. It can be displayed in BTU or Tons. One Ton = 12,000 BTU. For example, if your label says 2.5 Tons, multiply this by 12,000 and you'll get the total of 30,000 BTU.
But if you can't find it on the label or the label is missing, you can get an approximate by measuring the room the unit is cooling/heating. The formula for calculating this varies from place to place due to weather conditions, and maximum/minimum temperatures where you live.
I live in the Caribbean and it is very hot here all year long, so we use this formula: length x width x 85°F
But this formula will be different if you live in the northern parts of the country. Do a research online to find the correct formula for your area if you need to use this method.
Posted on Dec 02, 2014
What does it mean when the clean filter come I washed fliter
Its sign of you air con filter has been dirty need go clean it .
Aug 07, 2016 | Arctic King 10,000 BTU Slide Casement Air...
I have an Air-con air conditioner and heating system
Check your filter, if it's clean check the condensate drain to be sure it's draining if ok your system has a leak and will need an ac tech to repair and recharge the system
Nov 28, 2013 | Air Con 9,000 Btu Split ditioner Wall...
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Hyundai 24000'btu ac outdoor unit con moter wirig what runing'starting'comon
Three pins Common is neutral. Start is start from relay, Run is run from relay Usually Common at top, Start bottom left, Run bottom right but check a manual if you can find one.
May 18, 2012 | Heating & Cooling
Not Cool
Measure room and calculate btu's
Formula Length times Width times Height Times Eighteen divde by Five.
Example: 12 x 15 x 9 x 18 / 5 = 5832 BTU's
Jun 03, 2010 | Panasonic CS-A12C Air Conditioner
Hayward pool heater Model CZ 250 will not ignite
if ignitor sparks i'd say its okay, more likely a gas valve problem.are you sure gas supply is on and purged of air?make sure gas valve(the one gas supply threads into) is in the on position
Jun 18, 2009 | Hayward H Series Pool & Spa Heater 400k...
Is there a list that will tell me the horse power of all air con systems
not sure on hp but 12000 btu per ton in model # CPLT036HTC EX 3 TON 42 3.5 24 2 TON ECT
Jun 09, 2009 | Heating & Cooling
Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
May 31, 2009 | Whirlpool Electronic Window Air...
Heating & Cooling Logo
83 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
