Question about Canon MG5350 Wireless PIXMA Inkjet All-in-one printer USB Cable A male
No power to printer
Turned power off as instructed then no response when turned back on. Screen advised refer to handbook
    Sergeant:
  • 262 Answers
Try moving to another plug. Just for giggles.
Posted on Dec 02, 2014
How to troubleshoot ink near full absorber?
Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
Jul 05, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
I turned my power off and when I turned it back on my Miele 5733 is beeping and giving me a 30 error code. How do I make it stop?
No handbook? Go online to the main Miele importer HQ or go to Miele in Germany website and usually there are handbooks to download. If not message Miele service centre and they will help.
May 20, 2014 | Miele Induction Cooktop
How To Reset Purge Counter on a brother mfc-j4710dw
Mar 03, 2014 | Brother MFC-J4710dw Color Inkjet...
How to fix the DCP-6690CW unable to clean 46 error
Jul 29, 2013 | Brother Ink for Dcp-6690cw and Lc-1100
I have a problem with my Acer Ferrari One computer. The screen turned black after low battery and now we can't make it work. I don't know where is a problem. Can you give me some advise what can I do?...
Hi. Try troubleshooting steps below if the computer is still turning on after you push the power button.
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30 secs
Plugged everything back in
Power on the computer
Jul 25, 2010 | Acer Ferrari One FO2001799 Netbook
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
My network does not recognize my hp printer.
Try visiting HP Support Page and enter your printer make and model. They have some pretty detailed instructions that should get you on you way. Here is the link.
Apr 23, 2009 | HP Office Equipment & Supplies
Message on screen
Try updating your print drivers:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
I have a D7300 printer serial No Q7057B bought from Staples about 6 weeks ago. The message appears on screen: "Ink system has failed. Unable to print". I have turned it off and removed the...
Try this one:
Reset the Printer to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Now please unplug and re plug the power cable at the back of the Printer.
Hope that helps......
Aug 27, 2008 | HP Office Equipment & Supplies
Error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board.
Dec 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MG5350 Wireless PIXMA Inkjet All-in-one printer USB Cable A male Logo
111 people viewed this question
old marine
old marine
