Question about Frigidaire Heating & Cooling
Where can I get a remote sensor for my Frigidaire 12000BTU split AC. The Model number of the unit is FSC12CM6A. The part number I need help locating is CE-KF32GW/iiY(S)
Searching web but no luck
Frigidaire ES200 Electric range - last night while making dinner, I noticed a strange light coming from in the oven. I looked inside & one side of the lower/bake element was literally in flames. I...
Hello Damaya,
I am sorry to inform you that this is not the proper model number of your unit. The model number you give is for a Frigidaire electronic air cleaner. Your model number should be located in side or around the facing of the oven or compartment below the oven. If you can post back to this thread I will be more than happy to locate the cow-rod you need for you oven and explain how to change out the part.
Thank you for using FIxya and please do not hesitate to ask questions.
Mar 09, 2011 | Frigidaire Kitchen Ranges
I have a 14.4 square metre office room, fitted with 12000btu split AC unit for cooling, will it be sufficient?
1tr could cover up area of 100 Sqft ( Nearly 10sqmtrs) 12,000BTU is 1Tr. Better you go with 1.5 Tr. Otherwise make any patrician work to short the area, if you can. Thanks.
Feb 01, 2011 | LG LS-L1210CL Mini Split Air Conditioner
The best pressure of gas in a split ac in
65 psi is the ideal pressure remember its not exceede from this pressure.
and it is valid for all season
Jun 05, 2010 | LG LSC121PMA Split System Air Conditioner
Indoor a/c remote control will not work. How do I manually
If you lift the filter cover, on the right you will see a wiring diagram. Above the diagram and to the left , you will see a small hole that is about a fourth of an inch in diameter with a rod in the middle. Touch the rod and the unit will come on AUTO. Touch it again and the fan will reduce speed. One more time and it will go off.
Feb 05, 2010 | Heating & Cooling
Remote doesn't work.
John I suspect that your remote sensor reciever on the ac unit is bad, you may need to replace it. Quite simple two screws and a plug in fitting.
May 04, 2009 | Heating & Cooling
AC remote not working
www.gree-ac.com this is gree website you will need a model and serial number from unit I would contact them to see who your local suppliers are or online order remote m# and s# would also help if available
Jan 04, 2009 | Heating & Cooling
Frigidaire 12000 BTU A/C window unit
The reason that it's doing that is b/c at first its running only with the fan butwhen the compressor clicks on it trips the breaker if you have other items running off that circuit "unplug them" [even turned off items can still consume some power]. Then try to running only the ac unit see if it works a 12000btu takes a lot to run, if this doesn't work the ac may be to much for your circuit to handle and a smaller unit may be needed.
Aug 06, 2008 | Frigidaire FAA065M7A Air Conditioner
Lg artcool 12000btu mirror model
1.check remore battery.if week change it
2.check indoor unit sensar of remote.
3.check sirkit board.
Mar 09, 2008 | LG Art Cool LA1000PR Air Conditioner
Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Feb 07, 2008 | Heating & Cooling
Heating & Cooling Logo
70 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
