Question about Frigidaire Washing Machines
How do i get the door open on a frigidaire front load washer?
I have a 6 year old frigidaire front load washer, and the door will not open, I've tried unplugging it, bumping it, holding options and select button, with no luck, it has drained but my clothes can't be recued.
    Filmmaker:
    Uploaded 5 video answers.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Check underneath the washer below where the handle is for a ring. pull to manually release lock.
Posted on Dec 02, 2014
Testimonial: "removed bottom part under door no ring to pull"
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
My front load washer frigidare door is rusty acsess door is rusted off its only 6 years old
Thank you for your post, debra!
I understand that the front of your Frigidaire washer is rusted. Typically rust is not covered under the warranty and in most cases, the door will more than likely need replacing. Could you please provide me with your model number? You can normally locate your serial tag (which lists your model number) on the upper front interior of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. Once I have that information I can provide additional information for your washer. -Matt
Aug 13, 2014 | Frigidaire Washing Machines
My washer front load is all rusty it is only about 6 years old
you have to clean that out or will ruin your seal, I would use WD40 on a cloth do not spray it in there,alsoalways leave ur door open after doing a load to let the tub and seal area dry out.
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
I had the same problem. The service tech came out and replaced the pump, it has been working fine ever since. I couldn't believe the pump went out in only a couple of years.
Jul 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Door Leak
Not usually ,replace the gasket if you cant re set the old one.
May 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Drum won't spin.
ck fuse on board with ohm meter in board ..cks open change motor bd..also possible door lock or door strike
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidair front-loader washer door remains locked
there is an Emergancy release you can pull to open the door it is either in the soap dispenser area or behind the front lint clean out door depending on your model
Mar 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
