Question about MagnaFlow 2002 Ford F-350 - 6.8L V10, to 15000 GVW, with federal emissions system - Catalytic Converters
On 2002 ford f250 v10 is misfiring. decoder says po355, coil E misfiring. what cylinder is coil E on?
My 2002 ford f250 v10 is misfiring after installing new coils. checked with a decoder and it says code po355/coil E is misfiring. which cylinder is coil E on?
    Problem Solver:
CYLINDER 5 IS COIL E
Posted on Dec 02, 2014
Both coils do not fire on 1 and 4. Will start but only running on 2 cylinders. Could both coils be bad or should I look elsewhere?
Part 3 -How to Test the Ignition Module and Crank Sensor ...
easyautodiagnostics.com > Ford > 2.3L
Mar 1, 2012 - Spark plugs for cylinders #2 and #3 get spark at the exact same time. ...voltage -12 Volts) to both individual ignition coils within the coil pack. ... Ford Mustang or Ranger (or 2.3L Mazda B2300), this is what you'll need ... for this 'Switching Signal' at the coil pack... but you can also test this ... 1991, 1992, 1993.
How to Diagnose a Misfiring Cylinder (2.3L Ford Ranger ...
troubleshootmyvehicle.com > Ford > 2.3L
Apr 3, 2012 - Bad Fuel Injectors can cause a Misfire Condition. ... the ignition system on the 2.3L Ford Mustang or Ranger consists of 2 ignition coil packs, ...
2002 ranger misfire rough idle - Discussion on Topix
www.topix.com > Ford Ranger
Jul 27, 2007 - My truck is giving the code misfire in number 4 cyl. I replaced my spark plugs, Wires, Coil packs (both of them) and all my fuil ... three (3.0L v6) go bad, the fuel/air mixture gets messed up. Judged: 2. 2 ... My truck runs rough only at idle. ...code for ford ranger 2002, 2.3 5speed. truck runs like a champ but that ...
Extremely stumped! I need the best and brightest 1994 Ford ...
answers.edmunds.com > Edmunds Answers
Jan 31, 2016 | Cars & Trucks
How do i test the coils on my 2001 f250 5.4 engine without a computer
You don't
Need to use a scanner in Mode #06 for cylinder misfires
Need an oscilloscope to current ramp coil primary & voltage
on secondary
If you have a PO 301 thru PO 308 --you buy a new coil &
walk it one cylinder at a time & drive at least 20 miles
Some coils only act up every 3 weeks & really bad & spike
the pcm & come back on the tps sensor
Real education to work on a ford
Interesting once you get the hang of it
Dec 16, 2012 | 2001 Ford F250 Super Duty Super Cab
Number 3 and 4 are not firing from coil on 2002 subaru outback 2.5
its faulty coil.
Get the compression test done on each coil.these will let you know if its faulty coil or not.
It can be issue with spark plugs or faulty spark plugs. Also get the compression test done for cylinders. If any of cylinder shows low compression then required, then that particular cylinder will cause misfire.
Also get obd codes scanned, the error code will let you know which cylinder is misfiring or all cylinders are misfiring.
For your trouble shooting I suggest you to refer the help oinks below. It has step by step details for many engine misfire issues.
Click the link below:-----
Ford Explorer Cylinder Misfire?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-cylinder-misfire.html
Engine Misfire codes on Chevrolet Malibu?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Cylinder 6 Misfire?
http://howtobyme.blogspot.com/2011/12/cylinder-6-misfire.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Ford Explorer 5.0L: Engine Miss?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-50l-engine-miss.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
Can cylinder misfire Damage the Catalytic converter?
http://schematicsdiagram.blogspot.in/2012/02/can-cylinder-misfire-damage-catalytic.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Chevrolet K1500 No spark, random misfire
http://repairhelpcenter.blogspot.com/2012/11/chevrolet-k1500-no-sparkrandom-misfire.html
2004 Ford F150: Engine Misfire and Lean Code?
http://whatisbyme.blogspot.in/2012/05/2004-ford-f150-engine-misfire-and-lean.html
1995 Toyota LS: Misfire at idle or low RPM
http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Toyota Corolla: Random Misfire?
http://technoanswers.blogspot.in/2012/04/toyota-corolla-random-misfire.html
2006 Ford Freestar: Misfire on Cylinder Number 2?
http://whatisbyme.blogspot.in/2012/06/2006-ford-freestar-misfire-on-cylinder.html
This will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
2003 lincoln navegator with code po300-po355 what that means?
p0300 is usually a random multiple misfire and p0355 is an Ignition Coil E Primary. The P0300 code is triggered because of the P0355 code. Go to Cylinder 5, 1st-Replace the coil, 2nd-Replace the plug, 3rd-Check compression
Jan 28, 2011 | 2003 Lincoln Navigator
My 2002 f150 is hesitating acutting out and idelling rough .my code reader says the engine is misfireing on cylinders 3 and 5. what could be the cause?
Take the coils on the cylinders that are misfiring and swap them with ones that are not and see if the misfire changes.If it changes to where the coils were put then replace the coils.Also check the plugs.Coils are known for going on these.Hope this helps.Good luck.
Jan 12, 2010 | 2002 Ford F150 Regular Cab
I have a Ford F250 Extended cab that started running rough and losing power this morning got Codes P0301 P0303 P1151 and P0171 What should i Do?
P0301 = Misfire cylinder #1P0303 = Misfire cylinder #2
P0171 = System too lean cylinder #1
Are you sure on the P1151 code? I am thinking this may be a P0151 which is O2 sensor related.
This looks like you have a fuel system related misfire. I would do a fuel injection cleaning service and then clear codes and see if the codes regenerate.
Jun 05, 2009 | 1997 Ford F250 SuperCab
Engine misfire #2 cylinder need to know running order
cyl 2 would be the second one fromt the front on the right. all locations are perceived from sitting in drivers seat.
May 04, 2009 | 2008 Ford F-250 Super Duty
2002 ford windstar showing obd2 codes po303,po304,po305 and idiling ruff and wont run over 45 mph and has low miles, how do i fix it ,thanks sincerely mark
might be the coil pack is bad, wires, plugs, o2 sensors, dirty injectors, catalic converter ( only if you smell rotten eggs ) . cylinders are misfireing.
Mar 23, 2009 | 2002 Ford Windstar Cargo
2001 f250 5.4 hesitates while accelerating
check for misfire dtc's possible coil on plug
Jan 15, 2009 | 2001 Ford F250 Super Duty Super Cab
Po720 location
the speed sensor is in the rear differential
Nov 25, 2008 | 2002 Ford F250 Super Duty SuperCab
MagnaFlow 2002 Ford F-350 - 6.8L V10, to 15000 GVW, with federal emissions system - Catalytic Converters Logo
164 people viewed this question
Top MagnaFlow Electronics - Others Experts
Lawrence Oravetz
Vernon Taylor
Are you a MagnaFlow Electronics - Other Expert? Answer questions, earn points and help others
