Question about Pioneer Xv-dv55 5.1 Home Cinema System
Hi i have a pioneer dv424 system and something went wrong with it the timer indicator flashes only but the system does not work or function at all help please thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 924 Answers
As to the timer function, maybe I don't recall any of these units ever having such a feature, however, that would out be the source of your issue anyway. Here's a couple of things to try first. Please check all your speaker wires, to be sure that there are no strands of fine wire touching the positive and negative terminals. If that is OK, open your manual, about 2/3 of the way to the back, and you will find a procedure called, "Return to factory defaults......or just Reset". You can try that procedure, but if that still doesn't remedy your problem, your unit probably has a condition known as DC Offset(meaning a damaged amp). If you need further information, or would like to inquire about a repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Dec 02, 2014
Microwave quit working, timer, number buttons timer, all functions on micro side of control panel quit working , timer numbers start etc.
Check to see if the fuse went. If negative then something is wrong with the electronic pad for the unit.
Nov 25, 2015 | Microwave Ovens
Flashing timer light
I doubt it's a flashing timer light, as Pioneers don't use one. I worked at Pioneer. What you have is a flashing MCACC indicator blinking. That means you have DC Offset, meaning a damaged amplifier. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 18, 2013 | Pioneer Audio Players & Recorders
Ive bought used Pioneer S- DV 424 home system and it come with XV- DV424 receiver but problem is when i put dvd to shows "NO DISC" and I cant operate it? can you help me please
You should of tryed it out before you bought it, It will probally cost you morte to have it repaired then what you paid for it, Minimun repair on any audio product now a days Starts at $90 i hate to tell you, End the problem that you have is with the lazer in it being shot, Minimun for replacement of the lazer is $180 end up,
Dec 05, 2012 | Audio Players & Recorders
On a pioneer xv-dv8 home theatre timer light flashes and the unit will not switch on.
I found the manual here:
http://www.pioneer-latin.com/downloads/xrb3033a.pdf
This their recommendation for your exact symptom:
Timer indicator is blinking and the system will not switch on.
• Unplug the system, then plug back in. Wait for one minute then switch on.
• Make sure the fan at the rear of the system unit is not being blocked.
• Check that the speakers are connected correctly.
• Make sure the voltage of the mains power source is correct for the model.
• If the problem persists, take it to your nearest Pioneer authorized service center or your dealer for servicing.
Jan 07, 2011 | Pioneer Audio Players & Recorders
Power Indicator dead On Pioneer A400
Hi, yes don't worry about it if you are sure it is working fine,it's just one of those things. Can you smell any sort of burning?
if not don't worry, but if you know someone who knows a little about electronics, it might just be a bad soldered connect on the neon, but neons are prone to blowing.
Well i'm just blabbering on here.
if it's ok leave well alone.
I hope this has helped in a sort of way.
Regards - Anthony
Feb 05, 2010 | Pioneer Audio Players & Recorders
Stanby light flashes 5 times breif pause then flashes 5 times again
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 20, 2009 | Sony Televison & Video
Pioneer XV-DV424 dvd player does not recognise bought dvds (region2) -we are in region 2. Recognises every other disc fomats eg DVD R, CVC, CD
Is the player a region 2? Just because you are in region 2 does not automatically make a player from another region change....accordianaman
Jul 20, 2008 | Pioneer Televison & Video
Pioneer Component Hi-Fi System XV-EV7.
pioneer xv-ev7 no power timer stand by only...
Jun 16, 2008 | Pioneer Audio Players & Recorders
Pioneer xv-dv424 power problem?
Try disconnecting all the speakers and turn it on. If it stays on, then a speaker (most likely sub) is gone and shorted, causing the system to shut down to prevent it from being damaged. Hooking up one at a time and powering on should help you find the bad one. If it still shuts down with all speakers disconnected, then you've got internal problems with the system itself. Time to visit a repair man.
Hope this helps, and please rate my advice, good OR bad.
Feb 04, 2008 | Audio Players & Recorders
Pioneer Xv-dv55 5.1 Home Cinema System Logo
154 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
