Question about Imperial Kitchen Ranges
How to change the oven door hinge on a imperial IR6 range
  • 126 Answers
SOURCE: We took the oven door off and now can't put it back on
i dont know how you got the door off the is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off
Posted on Dec 10, 2007
SOURCE: Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Posted on Mar 14, 2008
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
  • 125 Answers
SOURCE: where is the pilot light for imperial range oven
Hello. I will try to guide you, in the area that you described, there should be a pilot safety valve, and usually they have a red button you depress in order to get gas to the pilot. The pilot is usually beyond the safety, if you follow the pipe from the safety, into the burner area, that will lead you to the pilot. Put your match,lighter of choice there, while holding in the red button. wait approx. 30 to 60 seconds, then release. If all is well, your pilot is now lit, however you still may need some attention, like cleaning the pilot and orifice. If not, you will need possibly a thermocouple for the pilot/safety, or a safety. Either of those I would suggest you call a local service company, check your phone book under "restaurant equipment repair"
Hope that helps, and thank you.
Posted on Feb 22, 2009
  • 58 Answers
SOURCE: My Amana gas range's oven door will not stay shut.
they're not too bad, you may need to take apart part of the door to remove the hinges, just remember where everything goes as you take it apart. bring the door to the first stop, then bring the hinge pin locks into place to secure the door hinge lock, then remove door, or just slide the door up. then replace the hinges as needed.
Posted on Jul 09, 2009
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Eaton viking imperial electric,stove oven door will not close completelty; circa 1996. are replacement hinges still availible?
To the owner of the Eaton Viking stove RS3028W-1, yes you CAN get replacement hinges!
I too, have this stove model (circa 1996) with exactly the same problem and I have spent the past 18 months looking for replacement oven hinges. I was very frustrated at the thought of having to throw out a stove that cooks and bakes wonderfully and has not needed any repairs till now and having to buy one of the new subpar ones that constantly need repairs. Plus you can't do canning on the new stoves and the few remaining coil models are extremely poorly made.
I have found 2 places that carry the hinges.
1. Reliable Parts, 1-800-663-6060. This company is located in Montrea (St. Leonard), Quebec.
2. Appliance Shark, 1-800-663-1176. This company is located in Barrie, Ontario.
The part number for the hinge is: 318-024-741
I hope this is helpful, and may you have many more years of happy cooking on this great stove.
Sep 17, 2014 | Eaton Computers & Internet
How do I get my kelvinator stove's P 12 front door back
Without more information I can't be sure of your problem but I will make a guess that you removed the door without engaging the hinge locks. I am attaching a video that may help. All oven door hinges are not the same. Some require you to insert a screwdriver or pin in a hole to stop the hinge from retracting. My own oven door has retainers that snap onto the slot just above the hinge. When you remove the door these pieces are used to hold the hinge in the open position.
If the hinges are in the closed position you will have to figure out how to open them and hold them in the open position. Be Careful. The springs are very strong and can hurt you. I am including a link to a youtube video that may be the same as your oven door.
This free troubleshooting video shows step-by-step instructions on replacing the oven door hinge on Frigidaire, Electrolux, Gibson, Kelvinator, Tappan, and Kenmore gas ranges.
Door Hinge Replacement part 316456302 Frigidaire Gas Range Repair
Aug 15, 2014 | Kitchen Ranges
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
Oven door will not close completely no tension.siemens 6 hob.
I told bosch which is the same as siemens that the door hinges are defective. I even told them how to fix the problem without changing the hinges .If you add three washers on each hinge this will bring the door in to close the same for the bosch ranges. ps ex tech:)
Feb 24, 2010 | Ovens
Hinge, oven door #822144
Pull up on the door to remove it from the hinges.
Remove the pan drawer on the bottom. Remove the spring from the hinge to be replaced. Remove the hinge mounting screws. Remove the hinge.
Reverse this process to install the new hinge.
Jan 06, 2010 | Amana ACF7225 Electric Kitchen Range
My Amana gas range's oven door will not stay shut. It is not snug against the oven. Repair says I need new hinges. Are they easy to replace?
Jul 09, 2009 | Amana ACF3355AS Gas Kitchen Range
Adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
Nov 29, 2008 | DeLonghi Kitchen Ranges
Kenmore oven model# 790.79383401 door not closing
Do the hinges come out with the door or does the door slip off the hinges? If the hinges are on the door then there is no adjustment if not there should be an adjustment but you may have to pull the range out to properly adjust if it is a built in range. Also check the door lock.
Jan 15, 2008 | Ovens
Kitchen Ranges Logo
353 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Thomas Perkins
Thomas Perkins
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
