Question about GE Refrigerators
Replace bulb in refrig compartment of model TFX25JRYF_WW
  • GE Master
  • 744 Answers
Hello Brenda;
My name is Peter. I am a retired field service refrigeration technician.
First, This is a special bulb. You can obtain the bulb in your local supermarket. They are a little more expensive than household bulbs.
To remove your light bulb shield, pull down on the bottom of the shield, pull towards you and lift up.
Posted on Dec 02, 2014
How to replace the upper light bulb on my ref
Here ya go, the manual. Most fridge light bulbs are easy and quick to swap out. If it's covered by a clear cover, just remove cover and unscrew bulb. General Electric Side By Side Refrigerator Specification Sheet...
Nov 25, 2014 | GE Refrigerators
Lights in refrigerator compartment flickering
You have a bad electronic control board . This part is mounted on the back of the refrig , at the lower left corner , inside a plastic holder . The part number is W10135090 . It costs about $ 100.00 . This board , also controls the 2 control knob lighting .
Apr 21, 2010 | Refrigerators
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No longer cools
replace the control board especially if you've recently blown out refrige compartment light bulbs,this damages the control board
Nov 02, 2009 | Whirlpool GS6SHAXMQ Side by Side...
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Doesnt get cold
Ok, you will need to replace the Thermistor. This is a temperature sensor that is damaged. It is unable to register a true temp.
May 28, 2009 | GE Refrigerators
Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Jan 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
