Question about Toro Garden
How do I set the timing on a Toro Model 38050 snow blower
I have tried setting the magneto at several points. On one setting the thing at least tried to start but the other I got nothing
  • Toro Master
  • 1,169 Answers
This blower looks to the Tecumseh engines so try looking in the L head service manual for H 50-H80 engines under ignition timing.
http://www.mymowerparts.com/pdf/Tecumseh-Service-and-Repair-Manuals/TECUMSEH-SERVICE--REPAIR-MANUAL-3HP-TO-11HP-4-CYCLE-L-HEAD-FLAT-HEAD-ENGINES-692509.pdf
Posted on Dec 02, 2014
No spark on Tora 724 snowblower, mod. 38050 Ser. 1004915, new pts set at 0.020, emptied old gas, add new gas, condenser, plug, new coil. is there a grounding problem that I missed? Air gap setting behine...
Ground is only for shutting of engine if it not hooked up wont turn off. Take flywheel off and look at magnet. Make sure it has not moved meaning they are glued in place and wont fall off. Give it a wiggle and see if it slides. If it does pull magnet off and re-glue in place. You will see mark on inside where it was originally.
Feb 19, 2015 | Toro Power Max 726 OE Snowblower - 37771
How do I set the magneto timing on a Toro Model 38050 snow blower
all you need to set both points and mag spacing is a ole fashioned pack of matches , 1st remove matches from pack save one match , clean cut end!! with flywheel removed take out 5/32 screw on tin cover inside there will be points and condenser ,(if it's old model ) if not there will be a pick up coil and stator (finned lookin thing) take clean cut match Not the red end but the other end carefully move point arm away and put match in gap let arm go and slowly pull match out , use screw right next to it to adjust till match pulls out easyly with lil friction ! tighten all screws well install cover and screw for it , next obtain new aluminium shaft key , dont reuse old one , carefully install in key way and put flywheel down on shaft , tap once with a rubber mallet to seat it , install shaft nut and lock if it has one , unfold match pack all the way open hold with one hand in place where flywheel edge is flattest and carefully install magneto till it just rubs paper with a light skuff ,tighen all bolts well and install cover, start engine normally !! it should start right there if all your parts are good !! easy hah!!
Dec 02, 2014 | Garden
How do I set the Magneto timing on a toro 38050 snow blower
Use a .010 thousand feeler gauge ,or a business card if you don't have a gauge. Place between magnet on flywheel and magneto. Tighten magneto screws and you should be OK. If this doesn't start your machine check the shear key between your flywheel and crankshaft. If this shear key is dented as much as a hair, you could have starting problems. Let me know what you find. GOOD LUCK FRIEND.
Dec 02, 2014 | Toro Garden
Snow blower shorted out
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
My snowblower just started back firing,why?
Snow is melting on the engine and causing the spark wiring and/or magneto to short out...
Stop blowing snow and run the engine at a fast idle for awhile to dry off the motor...then it will work again..
heatman101
Feb 25, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Won't start, have cleaned filter, has gas in it, new spark plug still will not start.
You might try a new contact-points set, and making
sure the magneto that supply current to the spark-plug is clean and not obstructed. Also feel the compression: to do this remove the spark-plug and place a finger in the spark-plug hole. Then crank the engine. If the compression is good, you will feel it, and smell the gas/air mixture.
Oct 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self driven magneto setting
most any newer tecumseh or briggs will be .012 air gap setting
lawnboy is.010 setting
Jun 28, 2009 | Toro Lawn Mower With Toro Power Tools
It wont spark at all. No fire. Just put a new spark plug so that's not the issue. This lawnmower is only 1.5 years old. Thanks
Could be magneto bad, wire from magneto bad, ground on magneto bad, or the clearance between the flywheel and the magneto is rusted up if it was outside. Clean flywheel with sandpaper and set magneto gap using a match book flap.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
190 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
