Question about Air Conditioning and Heat for Chrysler 300M
Reservoir tank top has fluid to full line but bottom half only has a small amount of antifreeze in it. Is this normal I am loosing a small amount of fluid to my driveway not found from where yet.
Inspection only intend to add fluid
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
I would get the cooling system pressure tested to 15 PSI and look for loose hose clamps.
Posted on Dec 02, 2014
How to add antifreeze 2002 dodge intrepid
Open the container of antifreeze. Using a separate EMPTY gallon-size container, pour out HALF of the contents into the empty container, making sure not to spill any. Now, FILL the newly filled container with tap water. Fill the rest of the antifreeze with water, also. Now, you are ready to add antifreeze to your vehicle! Simply locate the radiator cap, (Don't touch it if it's hot!!) and unscrew it. Pour the desired amount of your mixed antifreeze into the radiator. Remember not to do this without proper knowledge!
Jun 26, 2016 | Dodge Cars & Trucks
Im trying to replace my coolant and I'm not sure how much to put in. It's the 4.3 L v6 in a 1988 GMC c1500
Don't know the exact amount but around 2-2 and a half gallon. Do this use one gallon straight antifreeze and one gallon water run engine for a few minutes then turn off. Check level and top off radiator. Add appropriate level to side tank
Apr 25, 2016 | GMC Cars & Trucks
How do I Bleed my clutch on my 07 honda cbr1000rr
  • 1 Fill the fluid reservoir and lightly tap the line, lever and reservoir to free any air bubbles trapped in the fluid. Keep the fluid reservoir filled to prevent air from entering the line.
  • 2 Pump the clutch lever three to four times, then hold it in.
  • 3 Open the fluid fitting on the slave cylinder a half turn. A small amount of clutch fluid should appear
  • 4 Close the fitting before the fluid stops moving and release the clutch lever.
  • 5 Repeat Steps 2 to 4 until the fluid's color is consistent and without air bubbles. Fill the fluid reservoir as needed.
    Tip: If you don't want to make a mess, slip a clear hose over the end of the bleeder so you can catch the fluid.
    I hope this helps.
  • Aug 28, 2011 | Honda FXDLI Dyna Glide Low Rider...
    Where do I put antifreeze in the car
    what kind of antifreeze?...radiator fluid?...if Rad fluid..look for your overflow tank, and add it there. The cap may be yellow, and may have "rad fluid only" printed on it.
    gas line antifreeze goes directly into the fuel filler
    windshield washer winter(antifreeze) goes into the wishy washy reservoir
    Jan 06, 2011 | 2002 Nissan Altima
    Buick rendezvous 2006 - red light says "brake
    Open the hood; look on the driver's side, toward the back of the engine compartment, where you will see a large drum mounted onto the firewall. On the front of this drum( the brake power vacuum booster) you will see a small, rectangular block with a plastic tank mounted on top. This is your brake fluid reservoir. On the side you will see 2 lines cast into the plastic; a ' full' line and an ' add ' line. Remove this cap ( black plastic ) and fill to the top ( full ) line. Replace cap and look over the system , since the brake system is designed to not need additional fluid as your brake pads wear normally. If you need to keep adding fluid, you may have a leak which could cause some serious braking issues. You may also want to have your brake pads inspected as you may need them replaced, as well as having the brake rotors turned ( resurfaced).
    I hope this helps!!
    Nov 05, 2010 | 2006 Buick Rendezvous
    How to change the radiator
    TO CHANGE RADIATOR FIRST YOU TURN OFF RADIO FIRST TO KEEP FROM LOSING RADIO CODE.DISCONNECT NEGATIVE BATTERY CABLE.RAISE FRONT OF VECHICLE SUPPORT ON JACK STANDS.REMOVE THE LOWER SPLASH SHIELDS.NOW YOU NEED TO DRAIN THE COOLING SYSTEM.CATCH COOLANT IN A LARGE DRAIN PAN.REUSE COOLANT IF ITS FAIRLY NEW.IF COOLANT VERY OLD CHANGE IT.PUT OLD COOLANT IN SOME EMPTY CONTAINER TAKE TO A GARAGE OR WHOEVER DISPOSE IT.DONT POUR ON GROUND.HARMFUL TO THE ENVIRONMENT.MOVE THE AIR INTAKE DUCT PASSES OVER THE TOP RADIATOR HOSE.NOW WHEN ALL COOLANT DRAIN OUT.LOOSEN UPPER AND LOWER RADIATOR HOSE CLAMPS.THEN DETACH THE RADIATOR HOSES FROM THE FITTINGS.IF THEY ARE STUCK GRASP EACH HOSE NEAR THE END WITH A PAIR OF ADJUSTABLE PLIERS AND TWIST IT TO BREAK THE SEAL THEN PULL IT OFF REMOVE SMALL COOLANT SURGE LINES FROM TOP OF RADIATOR THAT GOES TO THE OVER FLOW RESERVOIR..DISCONNECT COOLING FAN ELECTRICAL CONNECTOR.THEN REMOVE THE COOLING FAN.REMOVE DISCONNECT AUTOMATIC TRANSMISSION COOLER LINES GET READY TO CATCH TRANSMISSION FLUID THEN PLUG LINES. NOW UNSCREW THE FOUR BOLTS TWO ON EACH SIDE OF THE RADIATOR THAT ATTACH RADIATOR TO THE AIR CONDITIONER CONDENSOR CAREFULLY TIP TOP OF THE RADIATOR SLIGHTLY TOWARDS THE ENGINE.REMOVE THE UPPER RADIATOR SEAL AND LIFT RADIATOR FROM THE ENGINE.NOW IS THE TIME TO REPLACE THE UPPER AND LOWER RADIATOR HOSES WITH NEW ONES SINCE ALL COOLANT REMOVE I WOULD REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP.NOW WHEN YOU GET READY TO INSTALL NEW RADIATOR USE SHEETS OF CARD BOARD PROTECT RADIATOR FINS AND CORES FROM DAMAGE WHILE SITTING RADIATOR BACK IN PLACE.ONCE YOU GET UPPER AND LOWER HOSES IN PLACE ALSO PLACE SMALL SURGE HOSES FROM THE OVER FLOW RESERVOIR TO RADIATOR NEW THERMOSTAT AND TRANSMISSION COOLER LINES ALL HOOK UP. START POURING ANTIFREEZE IN THE RADIATOR OR OVERFLOW RESERVOIR IF RADIATOR DONT HAVE RADIATOR CAP ON IT.POUR A FULL GALLON ANTIFREEZE AND A HALF MORE IF LONG AS THE COOLANT STAYS ON THE COLD LEVEL MARK ON OVERFLOW RESERVOIR DONT OVER FILL.IF YOU POUR ANTIFREEZE IN RADIATOR KEEP POURING ANTIFREEZE UNTIL LEVEL STOP DROPPING AND LEVEL OFF AT RADIATOR TOP.START ENGINE CHECK FOR LEAKS. LET ENGINE RUN UNTIL IT WARM UP TOP RADIATOR HOSE GET HOT.WATCH COOLANT LEVEL IN RADIATOR OR COOLANT OVERFLOW RESERVOIR WHEN THERMOSTAT OPENS COOLANT LEVEL WILL DROP.ONCE YOU HAVE ENOUGH COOLANT IN THE SYSTEM COOLANT LEVEL WILL STOP DROPPING.THEN YOU READY TO GO.LET ENGINE SIT A LITTLE WHILE CHECK COOLANT LEVEL AGAIN.COOLANT LEVEL IN THE OVER FLOW RESERVOIR SHOULD BE AT HOT MARK FOR HOT ENGINE AND WHEN ENGINE COLD COOLANT LEVEL SHOULD BE AT THE COLD MARK.IF POUR ANTIFREEZE IN THE RADIATOR COOLANT LEVEL SHOULD BE AT TOP OF RADIATOR BELOW PRESSURE CAP.
    Oct 24, 2010 | Saturn L-Series Cars & Trucks
    I have a 1989 735i. I recently replaced a small radiator hose ( small one on the top 6'' curved) captured small amount of fluid ( one qt.) Replaced hose...added fluid, I thought I was done. I believe I...
    Have you tried a thermostat?I would go there first for any overheat situation.It is the cheapest and probably more than half the time,it's the cause.Also,air pockets in the radiator system are not really a problem.It works itself out relatively quick.If your radiator is topped off,always fill your external plastic tank,usually located on the sidewall,to the cold full line.Good luck Liz! Greg
    Aug 12, 2010 | 1996 BMW 318
    Car keeps saying stop check coolant, and service manual. The coolant fluid level is full.
    all you have to do is remove the three screws to the the coolant reservoir tank {drivers side} it should say g12 on it.Disconnect both hoses and the sensor from bottom of tank .Have a rag handy and perhaps a small jar to catch the small amount of coolant that will squirt from the hoses. Also remove the coolant from the reservoir and put in a clean container so you can put it back in the reservoir when your done. Take the coolant tank to your "garden hose" and flush it full blast. It works better if you leave the cap on.But you can take on and off and shake it repeatedly until you have thoroughly rinsed it.--NOTE the sensor is located in the bottom of the reservoir and over time gets clogged. You can even try soaking it in a de greaser and then the "garden hose" process. Then replace everything and attach all hoses and sensor and refill reservoir with the coolant that you put aside in the container.Start the car..This is the only thing that got my light to go off.
    Mar 22, 2010 | 2003 Volkswagen Passat
    Tube disconnected fron antifreeze holding tank to wherever it is supposed to go keeps losing antifreeze
    there is two small hose come out from reservoir. on of them(rear one) goes to coolant bypass line it is a small metal pipe goes all the way to thermostat housing other hose(front) connected to radiator.
    if you lose coolant from the bottom breathing hose on reservoir you may have air in coolant system you should bleed the system.
    Jun 24, 2009 | 2000 Pontiac Grand Am GT
    Air Conditioning and Heat for Chrysler 300M Logo
    Top Chrysler Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    elvis0427
    john h
    Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
