Question about Sewing Machines
The top thread keeps breaking. Have checked usual things but still happens - any ideas please
I have loosened the top thread holder, loosened the tension dial. It is OK until it gets to the needle and then it will not pull through without breaking. Very frustrating!
  • 579 Answers
After doing all the other adjustments did you try adjusting the needle down just a little. Try and see what happens. Please let me know what you find. GOOD LUCK FRIEND.
Posted on Dec 02, 2014
I have a janome DC4030 the top thread keeps breaking on thicker materials,
Make sure the correct length of needle is used and installed correctly. Sometimes it moves slightly out of the holder without falling out but just enough to affect the needle eye position which can cause this kind of problem. For thicker materials use either ball point or denim needles. As last resort the top thread tension might be too tight. Adjust the top thread tension.
Jun 09, 2017 | Janome Sewing Machines
The top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Dec 08, 2016 | Janome Sewing Machines
My thread keeps breaking after I sew just a little bit. I have changed thread, check it is put on correc. Please advise. Not sure if I have the top tension correct.
1. While threading put the foot up.
2. Give gentle tugs along the way. It should be without feeling any hangups.
3. Wherever the hangup is you must correct. Usually at the tension disc.
4 Sometimes the tension disc is tightening more than the indicator says. It should be about four. You can lower this tension setting until the stitch looks good.
5. You may have to take the tension assembly off and clean it thoroughly and sand any rusted spots.
May 30, 2015 | Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I'm in trouble deep-I was trying to fix an old
Good day!
Good day!
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
The thread keeps tightening and loosening causing the stitching to be off.
This happened to me once on my machine...Pfaff. There was a teeny weeny bit of thread caught in the tension disks. I slid a piece of paper between the discs and eventually got it out. Also....if you sew with cones the thread tension often goes off because cones are not meant to be used on the spool holder. Buy a special device for holding cones of thread....it sorta looks like those verticle paper towel holders. (a disk with a stick poking up from it) This will solve your tension problems and prevent needles from breaking all the time. If neither of these ideas help......maybe your machine needs servicing. Give these a try first.....might save yourself a big repair bill. If you can't find the cone holder........wind off thread from your spool onto a bobbin and use that as your upper thread.
Dec 21, 2010 | Euro-Pro 9125 Computerized Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
