Question about Brother Vintage Em-411 Electronic Typewriter Works
How do i get the keypad of my Brother Em 411 typewriter to work?
Taking the ribbon out to see if something is stuck
  • 19 Answers
SOURCE: I need manual for brother EM-530 typewriter
Go to http://www.brother-usa.com/typewriters/. Click on "Manuals." Select "Typewriters", then select your model number in the drop down boxes. Click on "View download." Click on the "Users Manual - English" and the manual will open in Adobe as a PDF file. Print it or save it to your computer for future use.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Posted on Apr 21, 2009
  • 85 Answers
SOURCE: manual book brother typewriter em 630
http://www.manualnguide.com/manual-get/11871/
Posted on May 18, 2009
  • 566 Answers
SOURCE: old typewriter Brother DELUXE 800 : ribbon reference ?
This is what you are looking for:
Brother Typewriter Ribbon spool black and red SC-20BR-BRO Compatible
The typewriter ribbons for use in Brother manual typewriters are usually all the same. What matters is the size (diameter and hight) of the spools.They differed only in that they were available in different colours (usually black or black and red) and in different materials: some ribbons were made of nylon (cheaper) and other made of silk (more expensive and higher quality) .
Maybe some old and good stationer's (papeterie) still carries them or has some in stock.
Or else you may want to contact the customer support service of Brother, in France, for advice on where to find them in your Country.
Posted on Sep 08, 2009
Testimonial: "Thank you for this reference and advice, it will be easier for me to find it in a good papeterie or Amazon.fr or Brother directly. Nathalie (France)"
  • 3594 Answers
SOURCE: installing new correction ribbon
Go to brother.com click on support a users manual is available there.
DickyO
Posted on Jan 23, 2010
  • 65 Answers
SOURCE: I need a ribbon for a Brother Charger 11 - a small
I have a Charger 12 that uses the same ribbon...
it's the regular size ribbon for manual typewriters.
Go to etsy.com or artfire.com and search for "universal typewriter ribbon"
They are also available at www.fjaproducts.com , but s/h is less on Etsy and ArtFire. Good luck!
Posted on Sep 03, 2010
How do I change the ribbon in a Remington sperry rand typewriter?
I was a typewriter tech for seven years. To see if your ribbon needs replace gently pinch it with your finger you should get some ink on them, if not, replace ribbon. Generally speaking, step one if your not sure how to change the ribbon take a picture before you thing , this will give you a chance to get it back together. New ribbon install/ 1. Look at the ribbon, with the hood up,type, and watch to see which spool is paying and which spool is taking up. 2. With your finger turn the take up spool until the ribbon is all on one reel. 3. Note how the ribbon sits in a guide on both right and left spools ( take a picture) 4. The tuff part,the ribbon is laced thought the "hammer block" where the type-heads go to strike the ribbon. (Take a picture) either you lift and lower and lift to " unthread" the ribbon or the other way around, it's not rocket science just note every move you make take pictures. If you get stuck or need further info send back info and pictures and we will go from there. Tip, when typewriters where replaced buy computers many typewriter service company were in the beginning phases of the copier revolution. Many type techs began working on both, you may find help from a long establish local copier company. Good luck, Bret
Dec 26, 2014 | Office Equipment & Supplies
Why is the ribbon tearing when it feeds?
Possible ribbon tear causes are:
1. Your Heat setting (Printhead temp) is too high - normal is about 10
2. You have something stuck on one of the surfaces the ribbon is contacting, i.e. a piece of label.
3. Something is out of place that is contacting the ribbon, i.e. a loose spring or wire.
4. Something is bent and/or out of alignment - look for where the ribbon starts tearing and examine that area carefully.
May 29, 2014 | Datamax DMX-I-4208 Label Printer
Brother CM1000 is not working when typing a caracters return wrong one for example when "a" return "fr"?
for em-530
"Make sure your keyboard setting is correct. If using standard 411 daisywheel, the keyboard setting should be at KB I. It is also possibleyour daisywheel needs resetting. Turn the machine off for 10 seconds and turn back on. If the wrong characters continue printing, change to a new daisywheel. If problem persists contact your Authorized Brother Service Center.
Dec 04, 2013 | Brother EM-530 Typewriter
I need help trying to fix my brother em 530. A spring that looks like it has something to do with the ribbon cart. has sprung out and I don't know how to get it back in!!!
Maybe a manual will help. Go to BROTHER.COM, click on typewriters, poke around there you will find a down loadable manual there.
DickyO
May 26, 2011 | Brother EM-530 Typewriter
Ribbon does not advance with each letter that is typed causing some letters to be faint
There is a chance that you are in overstrike ribbon mode.
Go to BROTHER.COM, Click mon support almost all Brother T/W manuals are there.
DickyO
Mar 11, 2011 | Brother EM-530 Typewriter
How to install cartridge ribbon on epson printer
Take a ribbon 10-15mrts ,open the cassette with twizer ,take the old one out.
Now ,put new one in such a way (That ribbon is there between the two gears) now rotate the gears & check that ribbon doesn't stuck anywhere.
Feb 16, 2011 | Epson LX-300+II Matrix Printer
Electric typewriter just aquired. Brother CE-70
Go to brotherinternational.com, click on support. Poke around in there you will find a manual for your T/W.
Dickyo
Dec 14, 2010 | Brother EM-430 Typewriter
I have a brother bem-530 typewriter and need the # for the ribbon
It takes BRO. T720, General Ribbon T333c or NUKOTE B135
Dec 09, 2010 | Brother EM-430 Typewriter
Replaced typing ribbon, now correcting ribbon will not work. Does not pick up
Be sure that the new ribbon is fresh, and that the knob is yellow or orange. If you had the correction tape off that mit has the dull side towards the paper.
DickyO
Aug 16, 2010 | Brother EM-530 Typewriter
Scanner mechanism stuck, making loud clicking sound
I've just got this problem after a powercut, whilst it was not being used but on. If you have only had it a few months send it in warranty.
Think I will have to take this apart and see if the scanner cable/ribbon/drive belt is caught on something or been stretched too much and can be replaced at all.
Its like at one end its caught and wont move the scanning head being stuck somehow, caught on something (doubtful tho').
Apr 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Brother Vintage Em-411 Electronic Typewriter Works Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
