Question about Home Security
Security light comes on and car wont start
Nothing have no idea what is causing it
SOURCE: car wont start
YOU SHOULD REPLACE THE IGNITION .
Posted on Jul 20, 2008
SOURCE: my security light comes on and i can't start my car
your car security system can not be disable but it can be bypass
but firts on these models it is the pass key the problem
on your key to strt the car you have a little round black thing with a little metal contact this is a resistance that is in your key when you put it in the hole to start your car it mesure the ressistance
and the you can start your car
the usual problem with this system is that in the ignition key lock cylinder there are two wire
and usualy one of the two wire just cut so i would remouve the stearing wheel and get that wire fix
hope that will help you !!!
the way to bypass the system is easy but you need to realy know what you will be doing
first you mesure the ressistance in the key in (ohm) and second get a ressistance the same value from any places that sells electronics
after you will find in your car the passkey decoder module (behind right side of i/p)
the two wires that come out of the box (B7 ppl/wht and B8 wht/blk)
cut these two wires and weld the ressistance in bettwen
this way you won t have to take your stearing appart
and your system will be bypass for ever
great day to you
Denis
Posted on Dec 13, 2008
  • 6 Answers
SOURCE: 92 buick park ave security light on car wont start
Someone put the wrong key (resistor value) in the ignition lock, you will have to disconect the battery for 3 min. Make sure you have the right key. Very important! Make sure the climate control is off before disconecting/conecting the battery.
Posted on May 08, 2009
SOURCE: 99 Bonneville wont start, Security light on
how to get the security light off and to get my car off security so it will stay running
Posted on Apr 18, 2010
judd0081
  • 334 Answers
SOURCE: I have a 2000 monte carlo ss 3800 series.
The problem might be your Vats security system. This causes the car to either "not start" or "shut down" while running, or start for 5 seconds and then die. (depending on the system) If the security light flashes, i guarantee that this is what the problem is. 1st trick, (if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. I did this in my regal for more than a year.
Cheap fix: Bypass the chip in your key. Temporary, but effective.
----- http://vats.likeabigdog.com/
Never worry again fix: Bypass the whole VATS/Passlock/passkey I or passkey II system entirely. Literally take it out, and throw it away. I just did this in my Regal. Took about an hour. Took longer to find the thing than it did to fix the problem. For a list of cars effected by this problem. See the NEWROCKIES link on the right side of their page.........
----- http://newrockies.ca?ap_id=judd0081
----- With this fix, you can take that whole Vats, passlock, passkey **** system out of your car all together. Good info on both sites
Posted on Jan 16, 2011
The security light comes on but it wont even turn over
When the light is on, the security feature of immobilizing car-wont allow starting-is active. Pretty difficult and time-consuming to permanently disable the security system, but some have figured it out and published their research over the internet. If yours gets worse, if the light stays on more frequently, you may want it permanently removed. I think it was a ruse by GM and car makers to add cost, and cause more frequent repair visits, but that just me.
Google "disable vehicle security system" or some such, to see results.
Dec 29, 2012 | 1999 Oldsmobile Intrigue
My car just wont start, coul the computer need reprograming?
Not just because the car won't start
Where did you come up with that?
Call a repair shop to come out
Dec 07, 2012 | 2003 Oldsmobile Alero
Car Wont Start
If you check your battery cables they might be dirty with acid also the starter wire might be loose on the starter if u get a screw driver and turn your key on cross the starter out it might start that way if it does then that means u might need a starter hope it helps
Feb 20, 2012 | 2000 Oldsmobile Intrigue
My car wont start, new battery, lights and everything works and comes on it just wont start. it wont even make a noise. the security light just keeps coming on and the inflatable restraint light also the...
The security light is what's causing this problem. Go to this link for info and some ways to fix this yourself.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 03, 2011 | 1992 Buick Park Avenue
My explorer wont start and i have a bad egr valve....when i turn the key nothing it doesnt crank or nothing
Could be many things..But first make sure your battery is good ..See if the lights come on,,that will tell if the battery is ok..Then check fuses..Use your manual and check all the ones that pertain to starting..Make sure your security light is not flashing rapidly..That indicates a security issue...The EGR problem will NOT cause the vehicle to not turn over..
Sep 19, 2011 | 2004 Ford Explorer
My van wont start. It acts as though it will, but wont. When you turn the key over, it will try to start (sometimes), but nothing, and other time it wont do anything at all. Also, the security light blinks...
If you see a SECURITY light, then this is whats causing all the problems. Go to this link and read it all. Will help inform you about security systems and possible solutions for you that you can do yourself.
Jul 02, 2011 | Chevrolet Venture Cars & Trucks
1997 buick Lesabre limited all lights come on,wont start
the ingnition switch has a wire broken that wont allow the computer to turn the security system off to let the car start
Jul 19, 2009 | 1997 Buick LeSabre
Kawasaki zzr400 (1994 model),streetfighter wont start
Its Starter relay may be causing main problem. You can try Yezdis starter relay as it can help you solving your problem
Jan 22, 2009 | 1994 kawasaki ZZR 400
Home Security Logo
394 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
