Question about Graco Baby Simpleswitch 2in1 Highchair And Booster Animal Time
How do i remove the timing chain cover on 2000 buick lesabre v-6 3800 engine
Have removed the harmonic balancer, seerpentine belt etc
I'm trying to remove a harmonic balancer. I've got to the point of taking it off. The pulley remover is placed. But the bolt when completely down only turns the balancer. How to fix please
Are you using a gear puller or an actual harmonic bal. puller? You can use air tools(carefully), or to hold the balancer/pulley still, use a chain wrench with an old belt wrapped around to prevent damage. I would not recommend a 2 or 3 jaw type gear puller.
Oct 17, 2015 | 1996 Buick LeSabre
How do i remove the timing chain cover on a 2000 buick lesabre custom 3800 v-6 motor. please show from start to finish
if you are going to work on this car.. I suggest that you obtain the Chilton Manual.. sometimes these are available to borrow from your local library.. if not try Rockauto.com and purchase one.
Further I suggest that you take lots of pictures as you disassemble so you can get it back together.
Dec 02, 2014 | Buick Cars & Trucks
the best thing to do would either google for a step by step diagram or purchase a shop manual for the job
How to replace the timing chain for 99 buick century 3.1 engine
need to remove harmonic balancer remove timing cover remove timong chine and gear and inatall the new one the timing markas are on the gear need to face the points aND REINSTALL ALL PARTS REMOVER BEFORE
Sep 25, 2014 | Cars & Trucks
How to change a timing chain tensioner on 2002 ford explorer
Pull your Serpentine belt, remove the Cam Belt Cover, (it may be advantageous to remove front wheel in the Cam Belt side) Remove the timing belt and time the engine to specifications, make sure you are on #1TDC, remove the tensioner and replace. if there is and Idler pulley replace that as well. You can use Spray Carb Cleaner to clean the pulleys before replacing the belt. Note, you may have to also remove the Harmonic Balancer and pulleys from the crankshaft.
Apr 28, 2014 | 2000 Ford Explorer
HOW TO REMOVE CAM SENSOR ON A 2000 BUICK LESABRE
You start by removing the passanger side tire. This gives you good access to the area. The cam sensor bolts to the front plate above the harmonic balancer. You might find it easier to also remove the belt just for access. The cam sensor is seldom the problem. The common problem is the magnet in the cam has fallen out because the plastic holder has broken. You can buy the magnet and holder at auto parts houses.
Mar 07, 2014 | 2000 Buick LeSabre
Harmonic balancer
remover the serpentine belt. Remove the water pump noting were each bolt came from for they are different in length. remove any hoses attach if there. Some models have hoses attached. . Use a gear puller to remove the harmonic balancer which can be rented at most auto parts stores. Gently pry the cover off
Sep 01, 2012 | 1995 Buick Riviera
How to remove the timing chain plate
Take the shroud & fan off , loosen alternator and air conditioner remove belts, remove belt pulley off face of water pump, drain radiator, remove water pump, remove belt off harmonic balancer, then pull harmonic balancer off of crank shaft, remove bolts from timing cover, and that will get you to the timing chain plate take the bolts out and remove it.
Feb 20, 2011 | Chevrolet Cavalier Cars & Trucks
How do you replace a crankshaft position sensor 94 buick lesabre
Remove drive belt. remove harmonic balancer bolt with impact wrench, get a balancer puller to remove balancer so you can replace sensor.
May 17, 2010 | 2000 Buick LeSabre
Bearing
check your harmonic balancer they where notorius for going bad on buicks.Remove the belt and grab the balancer and see if you can rock it back and forth by hand. if you can its the balancer
Sep 21, 2008 | 1996 Buick LeSabre
Graco Baby Simpleswitch 2in1 Highchair And Booster Animal Time Logo
560 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
