Question about Stihl Garden
How to remove a flywheel from a stihl bg55 leaf blower
  • Stihl Master
  • 1,169 Answers
Here the instructions from BG series service manual.
how to remove a flywheel from a stihl bg55 leaf bl - 25303994-umwaoyggzt11olwpfghe15hq-1-0.png
Posted on Dec 02, 2014
  • 4 Answers
SOURCE: i am looking for a part diagram for a Stihl bg55
28866.png This is breakdown and the part you will want is #8 and the part number is 4229 141 0501 #9 is an older version that was replaced with #8
The intake gaurd that your refering to I am guessing is the orange cover over the intake impeller and the number for that is 4229 706 8000 I tried to post the breakdown for it as well but it only allows one per page.
Posted on Jun 13, 2009
  • 257 Answers
SOURCE: Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Posted on Aug 12, 2009
  • 211 Answers
SOURCE: NEED TO KNOW DISTANCE BETWEEN COIL & FLYWHEEL
hi
0.35mm
regards savumihai71
Posted on Nov 05, 2009
backwoodsctr
  • 169 Answers
SOURCE: I have a Stihl BG55 Blower Gas comes out of muffler.
you have a piece of trash/debris under the inlet needle of the carb and or a welch plug has come out, ive seen this many times on zama carbs, if its within warranty bring it back to your service center for a new carburetor.
Posted on Nov 18, 2009
2strokeJim
  • 577 Answers
SOURCE: how do I adjust the carburator on my Stihl BG55 leaf blower
You can adjust the carb by turning the screws counterclockwise, the H high speed screw is the one closest to the Air Filter and the low L is closest to cylinder (Motor) Change your spark plug first, then run it at wide open throttle and slowly turn the "H" screw counterclockwise a little at a time if it blubbers then it is too far out (rich) so take it the other way till you reach peak R.P.M. s -then back it out opposite way till the sound of the R.P.M's just starts to drop and High speed is set. the low speed is adjusted at idle to where there is no hesitation when you pull throttle open, keep trying till you get a good acceleration with out hesitation, and you are good to go!
Posted on Nov 13, 2011
How do I adjust the carb jet when it wont run?
Carl,I bought one of these,the engine locked up and it couldn't be fixed,Stihl's are junk,went and bought a huskavarna from Lowe's,if buy your spark plugs,get them at Autozone,Stihl has a high mark up...
Mar 23, 2015 | Stihl Bg55 Bg65 Bg85 Leaf Blower Fan
How to replace a flywheel on a Stihl bg55 leaf blower,
it may. just make sure it's centered.
Feb 18, 2015 | Stihl Garden
Why doesn't my on/off switch work?
Check at the ignition coil that switch is ground the coil when switch to off position. If this is okay then double that this terminal is being ground fully by using a jumper that you can ground while the blower is running if it still does not kill it then the coil is bad.
Jan 27, 2015 | Stihl Garden
How to change flywheel on bg86c stihl blower
  1. Remove fan housing
  2. Remove spark plug and install piston stop.
  3. Remove flywheel nut.
  4. If flywheel is struck on use a puller. Stihl uses a knocker type puller that screw on the crankshaft and tapped by a hammer. Be carefully not the damage the crankshaft stud or the bearing.
  5. To install reverse the above skipping item 4. Just make the flywheel engages the slot in the crankshalf. The flywheel nut is torque to 17 nM or 150 in lbs. Don't over torque the nut or damage will occur to the flywheel.
Dec 16, 2014 | Stihl Garden
Stilh bg55 spark plug setting
Hi
Stilh recommend 0.020 inch (20 thou), however I have found that 0.025 (25 thou) or 0.6 mm provides a better start and run arrangement.
Regards
Jacko from down under
Apr 26, 2014 | Stihl Bg55 Bg65 Bg85 Leaf Blower Fan
Stihl power pruner serial number
The serial numbers on the FS130, HL90K,HT101 and BG55 would be on stickers if they are still there... The MS250 serial numbers are located on a 'flat' by the side of the exhaust and sprocket cover. (depending on the year of manafacture)
Jun 27, 2013 | Stihl Garden
Nov 18, 2009 | Garden
Garden Logo
348 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
