I have a coleman modulating furnace it is propane The buners seem to be corroding
Replace burners last year
    Master:
  • 571 Answers
There are 2 types of burners. Atmospheric (or ribbon) type & inshot. I would imagine yours are Atmospheric...the longer type burners that protrude into the heat exchanger if they are corroding. Which also means you have an older furnace. Condensation can occur if there is not enough removal of flue gas...or... water is getting down into the burner from the flue. Have someone check the draft pressure to see if it has a proper draw when running. Coleman Evcon also made a furnace that is called a blendaire system. This system has a lower control board @ the furnace & and upper control board in a fan on the roof. The purpose of the fan was to blend air into the return from outside via roof fan to introduce fresh air in a tightly enveloped manufactured home, along with pressurizing the attic space to help keep the attic dry. If you have this type of system, your motor may be not working on the roof. Good luck!
Posted on Dec 05, 2014
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
We have a coleman electronic ignite propane furnace for a mobile home it is not even 3 winters old. Regulator just replaced, tenant ran out of gas. We turned off the power and reset the computer-the...
This furnace should have a diagnostic light that will give you a starting point where to look. It is located on the control board and will blink a code. If you remove the panel with the door switch on it, you will erase the code. Look for a small viewing port that looks on to the circuit board. Once you get the code, look on the wiring diagram for a explaination of the codes.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 24, 2010 | Coleman Propane Forced Air Heater...
Hi~ i have a coleman-evcon heater in a mobile. The heater comes on when the thermosat is turned up to, say 65 from 55, then before the air blown out is even really warm, it shuts off. it runs on propane,...
Jan 13, 2010 | Coleman Propane Forced Air Heater...
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
I have a 15 year old Coleman Propane 130,000 Btu force air furnace, Model #BGU13020 forced air furnace. Afer the unit runs for 5 to 10 minuets, the flame will start to shuter and then it will trip the heat...
DO NOT attempt to repair this yourself. LP gas is a very unforgiving gas. Sounds like your heat exchanger is plugged. Yes it can be removed and checked, BUT it is not recommended. Trust your local repair tech. Any heater 15+ years old should be discarded.
Dec 26, 2008 | Coleman Propane Forced Air Heater...
Have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Dec 04, 2008 | Heating & Cooling
I have a coleman propane furnace in my home that is 30 yrs old. you can light the pilot but when you turn up the thermostat so that the burner will light and the fan will blow the pilot goes out after a...
watch your flame on the burners and see if the flame changes when the blower starts if it does and makes the flame jump around you have a busted heat exchanger
Nov 22, 2008 | Heating & Cooling
Coleman Propane Stove 2 Burner 5430E700
Ho cold waas it out? remember that when its cold out the presswure of the propane tanks are real low and you have to warm them for the pressure to go up. if your by your car then you can place them inside with the heater going till they warm up ofr now worm them up inside first. good luck
Sep 06, 2008 | Coleman Propane Grill Stove 9921-700
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
