Question about Netflix
How come I'll be watching a series then it's gone Example cannot find The Blacklist, SOA, Peaky Blinky to name a few
    Top Expert:
  • Netflix Master
  • 11,573 Answers
Check the attached links,instruction and guides, Good luck with your Netflix
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Contact Netflix
Posted on Mar 17, 2016
    Sergeant:
  • 320 Answers
Netflix buys license rights to show movies on their service. Sometimes they are temporary.
You may check Amazon or Hulu Plus streaming services, sometimes they will pick up series netflix drops.
Otherwise for many of us, it's off to the store in hopes of a box set sale.
Posted on Dec 02, 2014
My laptop will not turn on
A) Power On switch is no good.
Power On switch is usually on a Power Button Board.
B) AC adapter (Charger) could be bad. Hasn't charged Battery either, so there is NO power going to the laptop.
AC adapter needs to be checked for output voltage.
It's DC output voltage, and voltage depends on laptop. Usually 15 Volts to 19.
If the laptop manufacturer name, and model number was stated, I could tell you.
C) DC Power Jack problems.
The DC Power Jack is the jack on the laptop (DC_IN), that the AC adapter plugs into.
DC Power Jack either is soldered directly to the motherboard, or has wires attached that end in a small male plug. Unplugs from motherboard to remove, plugs back in to install.
D) Bad Power MOSFET's on the motherboard.
Example using HP Pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
The Fairchild Semiconductor Industries - FDS6679 - Power MOSFET is obsolete.
Cross reference example is FDS6679AZ.
Price is $1.01 USD,
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMshyDBzk1%2fWi1qxDdW%2fXBi2qgMuZEfLVO4%3d
Alpha & Omega LTD - AO4407 is also obsolete. Cross reference example is 78 Cents USD.
http://www.youtube.com/watch?v=3NN7UGWYmBY
http://www.youtube.com/watch?v=5uiroWBkdFY
Post the manufacturer name and model number.
Model number can be found on bottom of laptop.
I ha-te giving generic one-size-fits-all information.
Post back in a Comment.
Regards,
joecoolvette
Mar 01, 2013 | Computers & Internet
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
I can't get a Google email account because it says
from what you wrote, if you don't already have a gmail account, then someone else thought of the same user ID name that you did & that means that if you wanted to use the Id name you'd have to add some
thing like ( example- superperson@gmail.com,, & you wanted the same Id name try 1superperson2@gmail.com & see if that will work, if not you'll have to think of a different name.)
Feb 28, 2012 | Google Computers & Internet
Can you email me the instructions to put together the char grill santa fe series
Try here - they don't list a Sante Fe series, but they do have an Outlaw & a Wrangler listed so they may just have different regional names for marketing. Most of the designs have the same basic layout so look thru the lists & I bet you'll find directions for your Sante Fe series. Good Luck.
http://www.chargriller.com/index.php?option=com_content&view=article&id=16&Itemid=18
Jul 04, 2011 | Char-Griller Char Griller Pro Deluxe...
I have a digital watch SHARP made that says SUNDAY when really it is TUESDAY how can i get watch to say the right day?
Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • 4 Use resources available to you. There are thousands of digital watch styles on the market, each with slightly different setting methods. When you buy a watch, tuck the manual away in a safe location for reference. If you don't have the manual, do a website search. Most major manufacturers keep their manuals online for easy future reference.
  • Jun 28, 2011 | Watches
    How to download sound drive which was deleted by mistake.
    Do you know the type of sound card you had? If you do, a quick look on the manufacturer's website might be your best option.
    For example: If you had a Sound Blaster sound card, you could search Google for "Sound Blaster drivers," and look through the top few results until you found the official sound blaster page. There are also large directories available for finding the specific drivers you need.
    For best results, you'll want the name of the manufacturer, the type of card, as well as the version of the operating system you're currently running (Windows 7, for example).
    Best of luck!
    May 02, 2011 | Computers & Internet
    Windows vista crapped out after service pack update. How do I restore my hard drive?
    Start your computer, during bios loading press F8 repeatedly. You'll gone see in next screen few option to start your computer. Choose "Last known good configuration" and press enter, from next screen choose a restore point before service pack update was installed and follow the steps from that window, after that you'll gone have your computer restored. This in case you don't have system restore closed. If this is not work write a message and i'll give you another method to repair your computer a litlle bit heavier.
    Apr 28, 2011 | Everex StepNote NC1500 Notebook
    How do i copy the videos from youtube and paste to my desktop and i can play without internet connection
    You can use some program to help you save youtube videos to computer, the one I'm using now works well on me. After you download the videos, you can watch them off line.
    Apr 20, 2011 | Computers & Internet
    My watch battery low. watch name MOVADO series 800
    mcdevito75 here, Movado a FINE watch, BEST BET, look for a small watch repair shop in your area to change the battery, Movado watches have a very good over all value and any damage can lessen that value, not to mention the jewelers screwdriver you"ll need to change that battery.
    Jul 09, 2010 | Movado Series 800 Watch
    Netflix Logo
    98 people viewed this question
    Top Netflix Computers & Internet Experts
    David Payne
    David Payne
    L Pfaff
    L Pfaff
    Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
