Question about Consew 226R-1
I have a Consew 226 R1 sewing machine. The needle won't stay in place. Do I need to replace the needle bar clamp? Is there a site I can go to download a service/repair manual for this machine?
  • Consew Master
  • 1,860 Answers
You would have to check with Consew about a repair manual, it would be a good idea to replace the needle bar clamp.
Posted on Dec 02, 2014
kevin000
  • 1847 Answers
SOURCE: consew 226 r sewing machine
Take the bobbin out and check for dirt or broken thread in the hole.
Posted on Sep 15, 2008
SOURCE: I have a Consew 230
www.sewusa.com can provide a manual
Posted on Oct 09, 2008
  • 71 Answers
SOURCE: service manual for a consew 106rb
Hope this helps! Let me know if it not the right manual, and I will find you the correct one.
http://consew.marginspluslive.com/images/products/parts%20books/106R.pdf
Posted on Oct 31, 2008
  • 3 Answers
SOURCE: How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Posted on Jun 16, 2009
  • 26 Answers
SOURCE: Consew 226 breaking needles
I posted an answer to this a couple days ago. If the hook's hitting the needle you need to move it away from the needle. There's a small screw in the bottom of the machine that holds the hook mechanism in place. You need to loosen the screw and gently tap the assembly away from the needle. The hook should just pick up the looped thread as the needle bar rises. You can go to www.consew.com and download a pdf file showing the parts of the machine, also an owners manual. You have to click on the 224 machine. The manual's the same for 224, 225, 226. Or you can click on the 226R-3 - that's the same, too.
Posted on Aug 31, 2009
Consew 226 sewing machine will not feed the material through under the needle
The walking foot lever is not touching the material . is the knee pedal adjusted right . is the manul lever on the back down.
May 11, 2014 | Consew 226R-1
HI I HAVE A BROTHER XL-5011, the clamp that holds needle in place fell off whilst sewing now it won;t stay on thnxs
needs a new needle clamp screw & possibly the needle clamp too
try sewingpartsonline.com
Jan 11, 2011 | Brother Sewing Machines
I bought a consew 230 industrial machine, but when I try to sew on it the needle breaks. What do I need to check, the threading, needle or what?
make sure the needle is inserted correctly
check the needle clamp screw to make sure it's tight
the needle is to fine for the fabric being used
also make sure under the needle plate there is no lint
also in bobbin area
also check the tension
Nov 26, 2010 | Consew 206RB
I have a stitching issue. I have a Consew 205rb and I just replaced the needle bar. I have everything setup to work and it grabs the bobbin thread everytime the needle goes down and comes back up but when...
Once you replace the needle bar you have to retime the machine, why did you have to replace the needle bar? email me with your make and I will attach timing instructions.
drivewithken@blueyonder.co.uk or you can keep adjusting the needle bar until the point of the hook is just above the eye of the needle.
Apr 10, 2010 | Consew 205RB-1
I have a consew machine 226 and the needle thread will not pick up the bobbin thread .
your needle is in backward, the groove must point to the left.
Dec 30, 2009 | Consew 226R-1
I recently moved and can't find the belt to my Consew 226. Having problems finding a replacement. Can you help!
Go to www.consew.com and download the parts list for the 224 Consew. It's the same as the 226 for parts. Or, go to www.diamondneedle.com. They have nearly every part you're likely to need. I got bobbin case screws, a hook, some metal reusable bobbins, and some needles, all at very reasonable prices.
Oct 16, 2009 | Consew 226R-1
Sep 26, 2008 | Consew 226R-1
Consew 226 r sewing machine
do you have the user manual?
Sep 15, 2008 | Consew 206RB
  • Take the side plate off and also take the needle plate off
  • Take the presser foot off, and put a new needle in the machine.
  • Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
  • Then, turn the handwheel toward you until the top line is where the bottom line was. Note: At this point, the tip of the hook should be directly in the scarf of the needle.
Jul 22, 2008 | Consew 206RB
Consew 226R-1 Logo
163 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
