Question about GE Adora Dishwasher. Built-In Tall Tub Dishwasher in Stainless Steel
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Worked fine until yesterday
    Sergeant:
  • 251 Answers
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Posted on Dec 03, 2014
We have a GE Triton XL dishwasher that was working just fine until yesterday when all of a sudden I was running it and left the room, came back about 20 minutes later and the smell of something burning was...
Automatic DISHWASHERS...
DIRECT SUPERVISION is not required
(forget about blaming yourself).
A common issue is supply leakage moistens what amounts to be (the equivalent of) a WATER-COP...
(a trade marked name for water detector)...
STOPPING the machine before it completes its
wash cycle.
Be prepared to replace the supply hose.
(JUST A PERSONAL opinion: BRAIDED METAL)
Carnac the Magnificent
Apr 07, 2017 | GE 24 in. GSD6660GSS Built-in Dishwasher
Funny sound while operating
This happens some times. some times the dishes move due to water pressure!
Reorient the dishes and observe.
May 20, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher with one inch of water in bottom when complete
undo the drain hose from your drain and put it in a 5 gallon bucket and see how it drains your sink drain maybe stopped up or if it drains into a disposal it may be stopped up
Apr 24, 2009 | GE Adora GHDA656LSS Stainless Steel...
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
Refrigerator not getting cold
Chech blower fan POSSILE Burned UP clean coils see if fan works, or check compressor in supper HOOOT, possible burned.
Smell , does it smell like like burming tar or burned food.
Sep 26, 2008 | Sub-Zero 690 Side by Side Refrigerator
Built in ge dishwasher push button
Mine is doing the same thing. I just removed the motor & it is definitely where the smell is coming from. Mine is about 3 years old.
Aug 09, 2008 | GE Dishwashers
It is 4 year old.For 2 months after starting,there was funny sound,and it would start.but from yesterday it stopped totally.last evening when i started,there was smell of something rubber burning,and the...
IF IT IS A WHIRLPOOL DRYER, A FEW YEARS BACK THEY CHANGED THE IDLER PULLEY FROM A WHEEL DESIGN TO A TEFLON GLIDE. THIS DIDN'T WORK AND THEY HAVE GONE BACK TO THE PULLEY DESIGN. IC THE BELT BROKE OR BURNED IN TWO, YOU WILL NEED TO REPLACE THE BELT AND IDLER TOGETHER. GAIN ACCESS BY REMOVING TWO SCREWS UNDER THE LINT FILTER. LIFT OUP THE DRYER TOP AND REMOVE ONE SCREW FROM EACH FRONT CORNER HOLDING THE FRONT TO THE SIDES. THEN TILT THE FRONT OUT AND LIFT OFF OF THE BOTTOM SUPPORTS. NOW YOU HAVE ACCESS TO EVERYTHING.
REMOVE THE DRUM AND INSPECT THE IDLER. IT SETS BELOW THE MOTOR PULLEY AND KEEPS TENSION ON THE BELT.
Apr 16, 2008 | Dryers
Won't wash, just sits there and electonic buzz noise
check around the element.if you have calcium build up on your element it will smell too
Nov 12, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Adorda dishwasher
This one is a known issue and an easy fix. Use a tie wrap to securely tie the water tube for the middle spray to the upper basket. That's it. Believe it or not, it's that simple. You may want to secure it at the front and the back. To test this you can use the tie wraps used to closed the plastic grocery or bread bags. If this solves the problem you can buy a bag of nylon tie wraps from any hardware store. I had a similar problem with another GE model with a similar problem. The dishwahser used to make a horrible grinding noise during the wash cycle. One I secured the middle sprayer arm the grinding noise went away.
Sep 20, 2007 | Dishwashers
GE Adora Dishwasher. Built-In Tall Tub Dishwasher in Stainless Steel Logo
161 people viewed this question
Top GE Adora Dishwashers Experts
Are you a GE Adora Dishwasher Expert? Answer questions, earn points and help others
