My washer LTF2940FS1 won't start. The display flashes between the time (wash) and LOC. I unplugged for 30 seconds and nothing changed. I pressed cancel and nothing. I also tried cancel and
See above in my question. Thanks
LOC is the door interlock has failed and needs replaced
its a £10 unit from ebay two screws and a plug
try the door lock unit first
Posted on Dec 02, 2014
What does LOC mean on kenmore elite washer ?
Press the Options and Select buttons at the same time and hold for 3 or 4 seconds to unlock the control panel. Best Wishes
Sep 04, 2014 | Kenmore Washing Machines
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
FRIGIDAIRE LTF2940FS1 Error Code "PAU"
Hi
PAU is short for pause; the machine detected something wrong so it paused itself. Unplug it from the wall for a minute and plug it back in, it may reset. Once you plug it back in, it should display a Numerical code. You need to find out what's that error code mean.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washer model44082 will not work. It flashed err and LOC. I have unplugged and tried to cancel.it still flashes err and then LOC.
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore HE2 Plus Front Load Washer
Push any button and 'loc' flashes seems to be locked out
Press Options and Select at the same time and hold for 10 seconds or until "LOC" is no longer displayed to unlock the controls. Press and hold the same buttons for 10 seconds until "LOC" is displayed alternately with the estimated cycle time to lock the controls. Unplug the machine for at least half an hour, if pressing the buttons does unlock the controls, to forcibly reset the machine control and eliminate the possibility of an electronic glitch.
Oct 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
LOC Blinking
Control Lock
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
