Question about Electrical Supplies
I have a medusa t1000 it has fuel in but will not start
2 Suggested Answers
  • 52126 Answers
SOURCE: What size /sort of spark plug do i need for a Medusa T1000 4 stoke petrol generator? Thanks so much anyone's help
use the same type that you took out of it .
Posted on Sep 07, 2016
How can I check my status at medunsa because since I have applied I have not yet being informed?
Still medusa is the only place where you can get the info. Only e-mail send to a real mail address provided by medusa, will arrive there. All other mail addresses won't.
Are you sure this medusa is not a name used with phishing?
Jan 12, 2015 | Computers & Internet
Medusa t1000 generator will not start
OK here's a list of things to check since I'm here and your there I have to start from the beginning:----Do you have gas-is it getting to the carburetor---is there a fuel switch connected to the ignition switch---is it working such as a magnetic needle valve at the bottom of carb shut off when the switch is off(battery equipped system)---others have a vacuum control regulator---- you can check to see if it will run by spraying a whiff of ether in the carb filter inlet --- if it runs for a second you have fuel issues---check for spark---you can do this by removing the sparkplug-check to see if the plug is fouled---if so clean-if not ---connect the plug lead back up and lay plug against the engine---- then turning it over to observe if there's spark--- if not check to see if it's equipped with a low oil sensor ---if so this may be bad or you are low on oil---another fault may be a bad I / O switch---usually these engines are equipped with an electronic self-generating ignition system and it shuts down by grounding the system at the start switch when it's turned off. At the other end of the spectrum do you have compression ---if not you may have valve problems or ring problems and /or other issues---best I can do from here good luck
Dec 02, 2014 | Electrical Supplies
Pearlcorder T1000 mac compatible?
No this is a Micro cassette trancribe unit it uses a foot control that it looks like a Mac connector but is not a Mac compatible if you are looking for the pedal here is a link to copatible pedal the original pedal model is RS-19 or better pedal is in this link http://www.tvps.com/Products/ECS-Olympus-IN-19-Heavy-Duty-Foot-Pedal---New__VE-IN-19.aspx
Dec 02, 2009 | Olympus Pearlcorder T1000 Desktop Cassette...
My T1000 will not erase tapes.
Press the erase and rewind button at the same time.
Nov 16, 2007 | Olympus Pearlcorder T1000 Desktop Cassette...
Electrical Supplies Logo
15 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
