Question about Beko Dishwashers
Hi, I have a Beko DE6340 which just stopped working. No lights or anything and have changed the fuse to no avail. Someone suggested cleaning the drainage pump completely but would that cause it to not
Hi, I have a Beko DE6340 which just stopped working. No lights or anything and have changed the fuse to no avail. Someone suggested cleaning the drainage pump completely but would that cause it to not even light up?
  • 721 Answers
With all dishwashers when you press knob or push button, they first start to empty out any remaining water. If yours isn't doing this it could be that your pump has clogged, or has died altogether. So at the point your at the answer is yes. Check all the lines to and from your pump to discharge. GOOD LUCK FRIEND.
Posted on Dec 02, 2014
4 Suggested Answers
  • 9 Answers
SOURCE: dishes don't get clean!
The problem is probably that the chopper/cutter filter is pluged. It needs to be cleaned
1. Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly out.
3. Remove overhead conduit. One screw at back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg to right (Clockwise) and lift off of the centre post. It can then be taken apart and cleaned.
4, Remove centre post (pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (Under assembly remover in 4. Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and lift the filter disc straight up. Clean thoroughly. I then ran a 'quick rinse' cycle with everything out.
Reassemble.
Posted on Jan 02, 2009
heatman101
  • 43501 Answers
SOURCE: Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
Posted on Sep 30, 2010
  • 3247 Answers
SOURCE: Hi there . Beko DWD4310
I can see a couple of possibilities as to why the on/off light is not turning on.
Either the door switch is faulty or the thermal fuse is blown.
I do not have access to a service manual - so cannot provide the actual details of the location of either of these parts.
Posted on Nov 24, 2010
Hi I have 20 month old BEKO washer-dryer WDR7543121W which stoped working completely.
Try the wall socket first, then the interference supresdor which is at the other end of the mains cable
Sep 08, 2017 | Beko Washing Machines
Anyone know anything about a beko dcrs76w tumble dryer not heating up? We have changed element & thermostat & cleaned filters etc but its still not working
Here are two ideas that might help, in the United States.
1) Someone sharp with an electric meter should check each and every place that should have electricity and see if there is any.
Start with the plug on the wall.
There should be 3 or 4 holes in the outlet for the plug that plugs in.
Two of the 3 holes, or two of the 4 holes should show a 110 -115 volt availability.
The other one or the other two are ground.
If only one shows current, you have a fuse or circuit breaker that is blown or "popped".
This is because one of the 110 volt lugs or wires makes the motor and controls work, and the other 110 volt lug is for the heating element alone.
2) If the 2 are showing current, go to the back of the machine and test the machine at it's wire connection.
Then, test each and every wire inside the machine for continuity.
There could be a wire burnt in two, a wire unhooked, a heating element with an "open", or thermostat that is intermittent.
God bless your efforts.
Dec 11, 2015 | Dryers
MY BEKO 765s washing machine, has stopped working mid load, on the display it is flashing iL but its smaller, it has also gone onto pause, and wont go on to start, also on flashing on 1200. This was a...
Hi if your beko 765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Dec 31, 2010 | Televison & Video
The standby light wont come on when i press the button and the plug fuse is fine and it was working about 2 hours ago any suggestions?
Check the power outlet with other devices,Change the A/C power cord.All that fail ur power board is gone,must be rebuild by changing parts or buy a new board.
Sep 17, 2009 | Beko 324250WN 28" TV
Cooks Essentials CEPC800 It just stopped working...no lights
You can join the yahoo group: PressureCookerRecipes and they have a file that shows step by step how to change the fuse for this pressure cooker. Hope this helps.
Apr 08, 2009 | Crock Pots & Slow Cookers
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
Neff extractor fan not working
Hi rags116,
I'm Harvey the Master Plumber.
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Kitchen Ranges
Dishwashers Logo
94 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
