Question about Cooktops
What if there are no hold down brackets on the cooktop and you still cant get it loose
Cant get a razor blade between the granit countertop and the cooktop to cut it loose. I did not live here when it was installed
    Master:
  • 388 Answers
Sounds like someone glued it down. You're going to have a fight on your hands. Maybe this can help:
How to Remove Countertop That Has Been Glued to the Cabinets eHow
Posted on Dec 02, 2014
5 Suggested Answers
tzweeb
  • 318 Answers
SOURCE: I can not separate the glass cooktop from the granite surface.
alot of installers will use a silicone glue to "seal" the unit to the countertop. what happens is that means you cant get it out without cutting the glue off first.
it could also be that the unit is very tight in the countertop.
also did you remove the "hold down" screws from underneath the unit first??? there should be a screw on each side below the unit.
one more thing... do you have a gas line under your counter? if not be sure you can get a gas line to it before you try to remove the old unit. most homes have a finished ceiling under the kitchen and it would be almost impossible to install a new gas line if its not already there.
Posted on Dec 29, 2008
aasc
  • 1606 Answers
SOURCE: Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Posted on Aug 08, 2009
  • 18 Answers
SOURCE: i just bought a 7904427 electric kenmore cooktop,
From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Posted on Mar 26, 2011
  • 18 Answers
SOURCE: Replacing an old jenn air
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
Brandon@Stonerepairman.com
406.471.0000
Posted on Apr 25, 2011
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
StoneRepairman.com
406.471.0000
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
I just bought a 7904427 electric kenmore cooktop, which isnt installed flashed to the countertop, there is 2 mm gap between countertop and cooktop, cooktop sits on the 8 brackets instead of the flat...
Jan 09, 2011 | Kenmore 30 in. 42701 / 42702 / 42709...
Plastic spoon melted on ceran stovetop. Used a
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Aug 24, 2009 | Whirlpool RCS3014 Electric Cooktop
Aug 07, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
What's best tu glue my cooktop on my granite countertop?
I don't think I'd glue it down permenantly. I just had to replace the ceramic glass on mine (a JED 8430 ABD) after it cracked. Thankfully, it wasn't glued down so I could replace it pretty easily (ordered part directly from Jenn Air). But some sort of seal to keep food out from under the cooktop would be nice. I just wouldn't go permenant. The fact that you have to tape the down draft to the external vent should keep the cooktop in one place (plus its own weight).
Feb 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Seperate a granite tile backsplash from an existing countertop
the back splash should be held on by silicone or glue very seldom are they screwed on i would bet it is stuck with adhesive silicone so score around the outside of the splash with a utility knife the remove it scoring around the outside will prevent sheet rock damage
Jan 08, 2009 | Jenn-Air JED8430 Electric Cooktop
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Removing and reinstalling
There should be removabe clamps attatched to the bottom of the cooktop which tighten with a screw to the bottom of your countertop. Loosen the screws to the countertop, then remove the screws that attach the brackets to the cooktop. The cooktop should then be able to be pulled out.
Apr 07, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Cooktops Logo
128 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
