Okai I have a Sylvania model number LD320SS1 and Imy won't turn on what should I do
    Top Expert:
  • Televison & ... Master
  • 42,882 Answers
There may be an internal fuse that is open or the power supply may have failed.
Posted on Dec 02, 2014
Code for sylvania LD320SS1 TV/DVD combo for RCA universal remote RCU600M
You can use code search on your RCA remote control to find something that handles some or all functions. If a search through all codes stored in your RCA remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jul 19, 2017 | RCA Televison & Video
I have a Sylvania flat screen with a built in DVD model number LD320SS1 and it won't turn on.it goes green then red and the yellow light is on for DVD. What should I do
contact customer service for sylvania
their number is Customer Service: 800.968.3429
unless you Purchased at Sears: 800.469.4663
Dec 02, 2014 | Televison & Video
My sylvania tv model ld320ss1 only displays colors and no picture. I Need to troubleshoot the problem please?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Sylvania model LD320ss1 base unit Stand
Parts are not available from the manufacturer because they are assembled in China and the components are ordered for a run of complete products, not spare parts.
Try ebay for a non working set that has a base.
Try monoprice.com for a stand that fits your set.
Aug 27, 2014 | Televison & Video
My Sylvania tv model number LD320SS1 screen is flashing red, blue, white screen when you turn it on
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 05, 2014 | Televison & Video
Sylvania HDTV Model LC370SS8 won't turn on.
u should check std-by volt .when u press power on , the power on volt must not b drop
Oct 09, 2012 | Sylvania LC320SS8 32 in. LCD Television
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Cannot find the remote control code for Sylania TV LD320SS1 i.e dish network. I have done the power scan but no luck. Thanks in advance for any help you can provide.
Hi my nameis Mike Houston of DISH Network, and I see you are trying to program the DISHremote to the Sylania TV. I am not sure if your TV is the Sylvania set, I will send the codes that gofor that TV as well as the steps for setup. 632, 569, 566, 536, 720, 733, 756,764, 512, 659, 505, 546, 568, 573, 600, 610, 652, 556, 506, 525, 664, 665, 666,671, 723, 724, 729, 660, 643, 002, 141, 672, 674, 677, 654, and 656. http://www.dishnetwork.com/SupportSection/remote-setup
May 06, 2011 | Sylvania LD320SSX LCD TV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
