Question about Crafts & Hobbies
My android box just stopped working there is power but no signal. I have stopped hdmi port to see if that helped
Started off juggling frog for hours then next minute says no signal?
Shuttle83
  • 1139 Answers
SOURCE: No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Posted on Oct 01, 2007
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
  • 51 Answers
SOURCE: my hdmi port is not working
I have Verizon Fios and there's a known issue with the motorola HD boxes that they have bad hdmi ports, the screen goes green and that's it, nothing I can do about it I just use component cables. You need to be sure it's your tv not the cable box. Try the hdmi on a dvd player or ps3 or whatever else you have first just to be sure it's the tv at fault not the cable box. If you determine it is the tv you need to replace either the main board or the video board depending on your specific tv model. Some have the video inputs on the main boards some have video boards.
Posted on Aug 22, 2009
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Posted on Sep 26, 2009
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
Vizio tv says no signal on any of the hdmi ports
Unfortunately, you fried the HDMI controller. Not necessarily part of the power supply "main board." (Not sure which board is the HDMI controller in your specific TV. It's usually a separate board by itself). Easiest workaround is to use the "Component" cable connectors. The downside is you only get 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people only see 1080P when viewing Blu-Ray discs. Aside from replacing the HDMI controller, the cheapest workaround for multiple source connections is to buy an HDMI to Component Converter A/V box, which allows you to connect multiple devices to one box with one set of Component cables connecting to the TV. Then select various "sources" via the box.
Mar 05, 2016 | Vizio E370VL 37 in. LCD HDTV
Hi. I own an LG 32LC56. HDMI1 port works just fine but HDMI2 produces a "No signal" orbiting message. What can I do?
Main digital board fault. Check and replace it. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 28, 2017 | LG Televison & Video
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
TV was not in use but storm came through this morning and we were without power for 2 hours. Now when I turn the TV on it is not receiving a signal through any of the 4 HDMI ports. Cables work ok,...
Processor could be locked up, unplug the set from the wall for 40 Min. and that reset it back to normal. If that don't work, than it will need repair.
Aug 23, 2011 | LG 42LH40 LCD TV
The hdmi wont work the av works I have tried all three hdmi plugs on the the tv and it says no signal could you please help everything I have is setup for hdmi
Tries tv and those cables or satalites boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgraded it softwares.Tv to do a whole resetting itself back to the factory setting.Than go into the tv Menu.Go into Video Setting,go down and do a resetting back to factory setting.By doing this steps for every components devices that hook to the tv HDMI hubs ports on the tv Tuner signal board to reboot and resetting too.Have very good chances all the HDMI hubs ports on the tv to work again.
Jun 26, 2011 | LG 42LC2D 42 in. LCD HDTV
HDMI cable was removed when TV on standby and X-box off. It was then replaced and we now have a message. "No signal. Check connection" and nothing else. Please can you suggest a fix? Have checked...
Might some how got that HDMI input port shorted?Tries tv unplug and that HDMI cable input it into another HDMI port,replug tv back about an hour later.So the tv resetting itself back to factory setting.Tv on goto tv menu,goto tv PICTURE SETTING going down to do resetting.This should resetting the whole tv Tuner signal board.These steps,should help ur tv HDMI ports functions again.
Jan 21, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
Jun 28, 2010 | Olevia LT42HVi 42 in. LCD Television
Crafts & Hobbies Logo
361 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
