Question about Samsung UN40D5003 40 inch LED HDTV 1080p 120Hz
Samsung 1080p led 40inch turns on to only a blue screen and nothing will come up on it
On your TV remote, press MENU and see if the menu comes up. We had the same problem but it was because we weren't using the correct set-up - our old tv was HDMI1, so we thought this new one used the same thing. But no, it uses COMPUTER as we have Wi-Fi. If the menu does come up, try each individual hookup it shows and see if that works. Good luck!!!
Posted on Dec 23, 2014
You need to tell bit more such as what device/ port you connect to,
has sound or not. So people have an idea if the connection pins, port or plug have a problem. If the tv itself has problem. may be the main- board failure or those internal wires which carrying signal to screen are not connect firmly. if that is a case, try to press the screen top edge see if you can get any different color on screen.
Posted on Dec 20, 2014
Samsung series 5. 5500 LED TV BLACK SCREEN
perhaps the backlight invertor driver circuit.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
See where the wires from the long LED strips on the both sides of the screen lead you to.
does your model have separate board for backlight ? or is it integrated with TCON ?
Aug 17, 2016 | Samsung 32" Class 1080p 60Hz LED HDTV -...
My tv isnt coming on. first it was a flashing blue light. Manual said it was the fan, checked and it's fine, now no led and no screen. Fan is still running though...
same TV same problem!! Only my LED is still on and flashing. The screen never actually turns on. I'm not sure if you tried to turn it off but I did and about 5 seconds later it will turn itself back on. Again, manual says it's the fan.. I popped the back open checked it and cleaned it but still nothing. Maybe trying to reboot but I left it on for 2 days straight and nothing came back to life. I just took it to a repair shop this weekend so I guess we will see! I will post any answer they give me!
Dec 01, 2015 | Toshiba Cinema 65UL610U 65" 3D 1080p...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
My screen turned blue and I can't change it back.
Try unplugging it from the wall outlet. Press the power button once to release any stored power. Plug it back into the wall outlet and turn power back on to see if this helps. If it is connected to a cable box make sure all the cables and connections are not loose. Check to see if the cable box is loose from the wall outlet.
Mar 31, 2015 | Samsung UN46D7000 46 Inch 3D 1080p Smart...
Light Blue Verticle lines in samsung UA46D7000LNXZN
flat cable on LCD display are bad,buy a new TV,it is a cheaper variant
Jan 17, 2014 | Samsung "Un46 D7000 46"" 3 D Led Lcd Tv...
Led lcd screen red
Go to menu on remote then to colour settings and see what it's set at
Jul 15, 2013 | Televison & Video
No power
replace the power supply board inside tv
Jan 30, 2013 | Emerson Televison & Video
Bought a samsung 60"led 1080p
It has nothing to do with the tv. Its all about the source. There are vey few sources that are capable of 1080p Blueray is one. Dish Network now has dish on demand in 1080p. Also that source has to be hooked up using high speed HDMI cable.
Dec 15, 2010 | Televison & Video
Samsung UN40D5003 40 inch LED HDTV 1080p 120Hz Logo
63 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
