Question about Dishwashers
Defy DW12 water pump runs continuously despite no water in the machine and won't go into next program. I have replaced the timer, still same problem
Replaced the timer
SOURCE: Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Posted on Aug 05, 2008
ucc7
  • 36 Answers
SOURCE: speed queen washer leaking & won't pump out water .....
Ok, so the leak isn't from the bottom?
If it is spinning before pumping out, the water very likely will rise out of the top due to centripetal force.
At this point, I would lean towards the timer being bad, since it is the "brains" of the outfit. The contacts that tell things to kick in (and stop) all are on this little item... at least on all the washers I have dealt with.
I don't see an age or model number for this machine, other than speed queen, so I really couldn't give much more advice without that.
Posted on Jul 10, 2009
SOURCE: frigidaire dishwasher #FDB435RFR1 Wash cycle runs way too long
your site sucks!
Posted on Oct 01, 2009
SOURCE: Defy Dishmaid DW12 stopped mid cycle and does not respond
Exact same peoblem. Did you guys have any luck?
Posted on Jan 11, 2010
  • 16 Answers
SOURCE: DE 3761 FS fills with water, emptying pump runs but does not empt
I would check to see if the drain hose has blocked.
Posted on Jan 24, 2010
Defy dishmaid DW12
You have a major short to ground which is tripping the breaker. Get an electrician to check the machine, it may be as simple as you have trapped the cable. Don\'t mess with water and electrics. Electricity is the silent killer.
Aug 21, 2014 | KitchenAid Kitchen Aid Diswasher Part...
Defy DAW370
time to replace timer/electronic control board and fix it.
You can get part from www.repairclinic.com
God bless you
Jul 11, 2013 | Motorola Mobility Defy Cell Phone
My dial goes in and pulls out, but now won't the cycle
Possible that the timer program unit has failed and so does not go into the program cycle. Check and see if there is any loose connections, remove the front panel to confirm the connections. If not the estimation for a new timer and the feasibility to replace must be thought of.
Jan 14, 2013 | Washing Machines
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
My washingmachine doesn't continue to the next phase of the program
Yes! it seems that the program controller unit is the suspect, but first you need to check with other set programs and see if the entire cycle goes through. If not this can be related to a processor gate failure to go into the next sequence.
Also check the water level sensor and the drain pump and push in all connectors to be fitting. MAke sure there is no moisture within or else you will need to use a dryer to clear off and check.
Jul 02, 2012 | Candy CBL160 Front Load Washer
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
Washer won't drain, rinse or spin
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
