Question about In Microwave Ovens
I have a microwave in which i have option only for timer no option for setting temperature how to use it
Just to roast khichiya ,papad n to heat cooked food
    Top Expert:
  • In Master
  • 36,279 Answers
Unlike a conventional oven, your microwave does not have a provision for setting a specific temperature. There may be only settings for different levels of heating such as high and medium and a special setting for thawing frozen food. The manual for your microwave could be a useful source of information regarding operation.
Posted on Dec 02, 2014
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Posted on Sep 15, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 17, 2007
SOURCE: the microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Posted on Jan 06, 2008
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
bestdarngood
  • 3037 Answers
SOURCE: microwave doesn't heat food anymore
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
Is it true that the use of microwave ovens destory the neutriunts in the food or water that is reheated in them?
According to a recent 'Ask Umbra' column on Grist, there are three factors affecting nutrient loss when you cook vegetables: temperature, time, and water. "Nutrients tend to be both heat-intolerant and water-soluble," the article says, which means that any method that requires a) cooking at a high temperature for a long time, and b) uses a lot of water will result in the greatest nutrient loss. (So by this measure, boiling vegetables is likely the worst offender.) It goes without saying then that cooking at a lower temperature for a shorteramount of time and with less water would result in the least amount of nutrients lost, and that's what the microwave accomplishes.So where did this idea originate in the first place? According to Grist, in 2003 a study from Spain claimed that steaming broccoli in the microwave caused it to lose 97 percent of its antioxidants, while stovetop cooking only resulted in an 11 percent loss. But critics say the study used more water than would ever be necessary in a microwave, and thus the results were flawed.Basically, water, not the microwave, is the most important factor when cooking vegetables, according to Grist. The less water, the better:Steaming, for instance, is a fairly good option because the veggies have less contact with water. Even better: Cook your veggies in a stew or soup, and you'll be able to slurp those escapee nutrients up. Stovetop stir-frying or saut?ing is also a good choice, assuming you don't go crazy with the oil. Baking and roasting are yummy, but don't forget that long exposures to heat will zap some of the nutrients. Of course, other arguments against microwaves have to do with magnetrons and radiation levels, etc., which is a whole other topic. But as far as nutrient loss goes, if microwaving is your preferred choice for cooking vegetables, than cook on. Just watch the amount of water you use!
Mar 02, 2015 | In Microwave Ovens
Need to know how to roast a whole chicken
Cooking meat is not a good idea especially chicken, few microwaves have a higher enough temperature to properly cook it, you are using a 700 watt microwave, the core temperature is simply not high enough to properly cook the meat. I strongly recommend the regular oven for proper cooking and safety, plus it will taste better.
Mar 28, 2012 | Haier 0.7CF 700W Microwave 700 Watts...
What is the highest power setting? choices are low, defrost, medium, roast and reheat. no high???
Most microwaves run high at default, if roast and reheat are given that is your high setting, take one cup of water and run for 1 minute in each setting, the water that is the hottest is the high setting.
Mar 19, 2012 | Emerson MW8625W Microwave Oven
I havent used this microwave before. Can you please give me step by instructions on how to cook a roast beef and vegetables
If this microwave is a convection oven, you don't give make or model, treat as a fan assisted oven. 20 minutes per pound and 20 minutes extra for the meat, veg is best microwaved for a few minutes except potatoes, put them in the dish with the meat. Cover to stop splashing and set temperature to 190 Celcius 370 in proper temperature.
I am getting hungry now!
Enjoy.
Feb 28, 2011 | Microwave Ovens
Will not heat up
1. Make sure the controls are set properly,that the oven selector switch is set correctly and that the temperature
switch is set to the desired temperature where applicable,make sure the oven timer is set to manual.
2. If nothing else on the Range,Oven or Cooktop is working then
1. Check the circuit breaker or fuse.
2. Test for power.
3. Test the oven elements.
4. Test the oven thermostat.
5. Test the oven selector switch.
Feb 03, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid microwave makes a loud noise and does not heat
try these
  1. Check timer and clock settings
  2. Reseat the element
  3. Test the element
  4. Test the element connectors
  5. Test the oven temperature control
  6. Test the oven selector control
pls rate my suggestion..
Jul 20, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My tappan microwave come on but does not heat up food
hi,
              When your oven doesnt heat up please do the following,
  3. Test the element
For more details refer to http://www.acmehowto.com/howto/appliance/range/erange.php
May 07, 2009 | Tappan TMS062E1 Microwave Oven
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
Took 12 minutes to heat up a roast beef sandwich (not frozen).
Hi there!
My guess would be that the magnetron is faulty. If you have a testmeter, unplug the terminals on the magnetron and measure between the body of the magnetron and either one of the terminals. There should be no reading. If you have a reading it is faulty. Then also check the High Voltage Cap. Cylindrical shaped metal item with two terminals. I would replace the Cap anyway. It's 9 Years old. Conclusion: Magnetron is faulty, runs Hot and then switches off the machine on the Thermal switch(located on top of the Magnetron). No problem with the food. Be sure to unplug the Mains before you check it out. The Cap may also still be charged so do take precaution. Good Luck,JUS004
Feb 29, 2008 | GE JE1640 Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
