Question about Samsung Refrigerators
My side by side Samsung fridge freezer of 10yrs (no issues) finally died. Found someone to take away and replace with a 3yr used RSH1NHMH. He brought in and either I misheard (even though I remember
Electrics tripping Fridge delivered and turned on after 2hrs Probable gas not settled? What checks can I carry out to ensure engineer is not ripping me off!
  • Samsung Master
  • 4,654 Answers
The compressor is most likely shorting to ground. Get your money back. If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Posted on Dec 02, 2014
  • 163 Answers
SOURCE: refrigerator will not cool
no there a is nothing you can do, they gonna change a card, and charge for the card and the job,now check for waranties maybe the card is on waranty...good luck
Posted on Aug 11, 2006
SOURCE: samsung fridge freezer rs21dcns not cooling
press for diagnose the power freece and power cool, you will get an information about the self diagnosis. you can call samsung and will get a clue what is going on. maybe the heating is not working well.
Posted on Oct 01, 2007
watugot
  • 290 Answers
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
SOURCE: Hi, The Earth Leakage Breaker (ELCB)
what is elcb
Posted on Nov 16, 2008
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
Samsung rsh1nhmh fridge freezer not turning on and tripping electrics.
sounds like electrical fault within your freezer any small fault will throw your contact breakers on your consumer box without blowing the fuse in the appliances plug
Aug 30, 2015 | Samsung Refrigerators
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
I dont now how to set temperature for samsung rsh1nhmh . All the light in the house vent off and the plugs . Now on the frige screen is only a flashing light. Nothing else
The refrigerator temperature can be set between 7?C (46°F) and 1?C (34°F) to suit your particular needs. Press the Fridge button repeatedly until the desired temperature is shown in the temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the Fridge button to set your desired temperature. After a few seconds, the Fridge will begin tracking towards the newly set temperature. This will be reflected in the digital display.
http://safemanuals.com/314159.php?k=2f8f21dfdc6e62cb4825d07d38bad88d&ID=471000&q=SAMSUNG%20RSH1NHMH
Nov 18, 2010 | Samsung Refrigerators
The door handle on my samsung RSH1NHMH freezer is loose how do I tighten it
You will see a small hole on the underside of the handle at the two points that the handle touch the fridge door,put a small straight nose screwdriver in this hole and turn 90deg which will expand the metal clip inside at the same time pull the handle away from the door and it will come off.You can then screw the handle holding clip into the fridge door and then push the handle back on.
Oct 18, 2010 | Samsung Refrigerators
Stop cooling every 5 days I defrost manual GSS201ETCBB
Does the freezer / fridge door close good? Check the hinges. Also check the seal and the amount of food stuff you may have close to the door. If you have an ice maker make sure you have it secured inside the freezer section.
It sounds like something is keeping the freezer door open or from closing good.
Mar 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Samsung rsh1nhmh loud noise from fridge side . open door noise stops
Same problem, phoned samsung and was told an engineer will come and fix my fridge freezer free of charge as it is a problem with all these models. 0845 726 7864 uk number option 4....
Mar 17, 2010 | Samsung RS2556 Side by Side Refrigerator
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Trouble with my Samsung RSH1NHMH fridge freezer
Hello
I have a Samsung RSH1NHMH fridge freezer unfortunately the fridge part will now only go down to around 6,7 degrees we have defrosted the unit but this has had no affect can you help.
Regards Sean
Aug 27, 2009 | Samsung Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
85 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
