Question about Sony Televison & Video
How do i fix a sony trinitron kv-27526 tv with no picture?
Tv was presented to with saying their was half a picture on top or streaks, but when I plugged it in it has no picture, I plugged a coax cable from a vcr, has sound no pic, I plugged in yellow video cable no pic. please advise. Warmest Regards Andy
  • Andy Mendez
    Andy Mendez Dec 02, 2014
    THanks for the answer.. I have an update, I tried a factory reset by holding the up arrow on the remote then pressing and rreleasing the power button on the tv. the picture came back for about 15 seconds then the bottom half went black and the top half had lines through it for about 5 seconds then went completely black again.
  • Andy Mendez
    Ok now I knudge the chassis on the side and i get the pic coming back, sometimesa 1/4 ways with streaks, sometimes 1/2 or all the way but briefly, I'm thingincold solder joint? or faulty or loose component? any idea where I should start my search now?
    Top Expert:
  • Sony Master
  • 74,666 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Dec 02, 2014
Testimonial: "Thank you for your prompt reply, i have an update posted on top I'll certainly sift through that website you offered."
techman
  • 3130 Answers
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Posted on Oct 16, 2006
techman
  • 3130 Answers
SOURCE: Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 22, 2006
  • 308 Answers
SOURCE: sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Posted on Dec 24, 2006
SOURCE: Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Posted on Jun 01, 2009
Karthik316
  • 187 Answers
SOURCE: Sony Trinitron TV - Keeps Blinking
Try this link
http://www.agoraquest.com/searchbb.php?addterms=all&forum=all&sortby=p.post_time&submit=1&term=trinitron%20blinking%20picture
pls rate my suggestion....
Posted on Jun 23, 2009
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My Sony WEGA Trinitron 36'' TV has red instead of green, how do I reset the picture or fix this?
try this reset in this see if it works
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Mar 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The top half of picture is completely back, please
you have a vertical problem it could be a cold solder joint on the vertical out put ic or a component failing in the circuit
if you have the tools a soldering station and some know how you can fix this
or you may want to contact a local for help with it
Nov 09, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Top half black and bottom half OK on 27" Trinitron
could be an easy fix, soldering the pins on the vertical IC (IC501 I think)may fix it. also check the standup board pins being loose/dirty on the left rear (if yours has one). best quick test is bang on the set and see if the top half comes back for a second, if it does you have bad connections, an easy fix if you can solder.
thanks
E
Jul 18, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
No picture, Standby blinks then goes out
Sony Trinitron XBR
Problem/ Standby Flashes Power button
Aug 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Oct 22, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Televison & Video Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
