Question about Canon Office Equipment & Supplies
Hello every one, i have iR Canon 2420 copier, first time i have a problem on the fuser and i changed it with the new one. After that the machine copy correctly but the text copied will be erased easil
Have changed the following parts, fuser,Pressure roller, and the element. The problem still exist. Thank u for ur feedback in advance.
    Master:
  • Canon Master
  • 553 Answers
Dear
The fuser unit consiting of two pars
1-fixing film assy. (Heter unit)
2-fixing unit-(Complete set.)
if you have replaced new fixing film assy. in old fixing unit-this may be the result due to the pressure roller and it allied parts.
if you have replaced complete unit then check you toner and paper properties.
Thanks.
Posted on Dec 25, 2014
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
  • 2072 Answers
SOURCE: Xerox Workcentre XD100 Accordion Jam After A Few Copies
What is most likely happening is the pressure and heat roller bearings and bushings are very gummed up.
When you remove a the fuser when its cold, try turning the heat roller gear, I would assume it is very very tight to spin.
What you can do it take the fuser apart, soak the pressure ( soft roller) roll bearings in some alcohol and then clean the heat roll ( aluminium) roller bushings and the end of the heat roll. Make sure you lubricate with some silicon lube the ends where the pressure roll mounts into the small holes in the nip fingers. That should help.
You can call a business called , ( you can google, The Parts Drop) and talk to Britt there. I am pretty sure he has the bearings for that machine. I don't work there, just have done business with them for years and they are top knotch.
You probably want to replace the gear also. Sometimes it can look really good, but be worn just enough to cause a problem.
Make sure you take a real good look at the condition of the rollers before you spend money replacing small parts, so that you don't wind up replacing 40 or so dollars worth of parts only to find out you do need the entire fuser.
Posted on Dec 01, 2008
  • 148 Answers
SOURCE: Upper (gray) fuser roller needs replacing, (tear on 1 side).
If you are handy it is not hard to replace the upper fuser roller you will need a small phillips screwdriver and pliars
the fuser lamp goes through the fuser roler so youmust disconnect the power leads to the lamp and remove the lamp
You do have to release the back side of the drive
gear on the fuser roller
when you install the new roller be sure to put some silicone fuser oil on the cleaning pad
take your time good luck
Posted on Jan 04, 2009
  • 117 Answers
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Posted on Mar 26, 2009
SOURCE: canon imageclass D860 System error E100
smudges of ink on copies
Posted on Apr 03, 2009
I have IR Canon 2420 copier machine it shows E000007-0000 please help me what is the problem Thank yoyu
as the error codes are cannon specific I suggest that you contact a canon service dealer and ask them what the codes mean
Sep 03, 2015 | Canon Office Equipment & Supplies
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
There might be an issue with the feed clutch or fuser. It depends on where it jams in the machine.
Sep 27, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Service manual Canon ir 2318
Hello friend, I have downloaded a Good canon iR2318 service manual from below link:
Canon iR 2318 2320 2420 2422 service manual:
http://goo.gl/dBXTt0
Good luck on repairs.
Aug 03, 2012 | Canon imageRUNNER 6000 Copier
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
Solution to solve system Error E007 on IR 2016i copy machine
The fuser unit needs replaced. You need a tech with a new fixing unit.
Dec 24, 2010 | Canon iR 2016i Black and White Copier
Paper keeps on getting jammed on my canon d860 copier . was todl the fuser needed to be changed. Would this solve the problem adn for how long? I am told cost is 125$ for the fuser adn 75$ to install . IF...
if you change the fuser asy by the book it goes about 80000 to 100000 copies.
If you only change the fixing film if it isnt goodly adjusted and if there is also problem with pressure roller then that would not be a good idea.
Im telling you these without seeing the machine or without knowing your monthly volume of copies.
These is small volume machine for "home usage", if you want quality and better machine buy Canon ir 3225N. These is serious office machine, with extended parts life.
Hope that helped!
Jul 27, 2010 | Canon ImageRUNNER 1670F Copier
52 people viewed this question
old marine
old marine
