I have sharp copier machine but problem (---) what salution
Sharp copier repair code F5-02
Here is a list of all Sharp Copier Error Codes
The Sharp AR-M205 is almost 12 years old now. It will be very hard to find parts for that machine unless you can find a low meter on ebay.
You may want to take a look here at some of the current Sharp copier models. It looks like the Sharp MX-M232 replaced this machine.
Oct 29, 2012 | Sharp AR-M205 Copier
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Jan 22, 2010 | Sharp AR-M237 Copier
Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Jan 20, 2010 | Sharp AR-M208N Copier
SHARP AR 5020 error F5-02
you reset your eror code program c#0#
May 30, 2009 | Sharp AR-5320 Black and White Copier
Ma photocopieuse affiche H4
salut ! le code H4 c'est une erreur qui vient du fuser ( la ou le papier passe et les rouleaux deviennent chaud)
Il faudrait checker la lampe de chauffage et voir si elle est intacte,
la deuxieme possibilite est le fuse de prevention de haute chaleur, (thermofuse)
L'une des deux est votre probleme. Salut, et Bonne Anne.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
22 people viewed this question
jasbo
jasbo
