Question about Building Materials
<!-- from fixya rte -->DIGIDOR GARGE DOOR-REPLACE BACKUP BATTERY - Building Materials
  • 36 Answers
1...open the battery compartment and get the model number of the battery.
it's the number printed on the side of the battery
(ex. NP24-12B) the manufacturers name might also be printed there but thats not quite as important because almost all batteries are known by their number for replacement purposes.
check the size of the replacement batteries to make sure they match with the size of your old battery to be sure it will fit in the existing enclosure 2...buy a new battery of that model number.
3...replace the old worn out battery with the new one.
4...test the operation of the unit to make sure everything went well, remember you might have to let the battery charge overnight before it will work correctly.
best of luck to you.
Posted on Dec 02, 2014
Battery is bad. I removed it and garage door opener is still beeping. It is driving me crazy. Help
as long as garage door is powered(plugged into outlet), then with a removed battery backup or a bad backup battery, the unit will beep to alert you to the issue. replace the backup battery with a new/good one.
Jul 11, 2015 | Chamberlain 3/4-HP Whisper Drive Plus...
Where can i find a manual for craftman garge door?
Probably needs an adjustment. I would check Sears website as they have lots of info there for products they sell. An operators manual should give you this info.
Jul 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
TI-84 Plus will not turn on. Batteries have been replaced.
Try taking out the backup battery. It is located in the battery compartment, behind a little door that you must take off with a phillips screwdriver. Leave it out for about 10 hours. If this doesn't work, try replacing the backup battery.
Hope this helps.
Jun 11, 2011 | Texas Instruments TI-84 Plus Calculator
Hi , i have a 2001 vw bettle that wont start ,i ve had the car 7 months and got the starter repalaced 3 times now as they telling me thats what the problem is (same garge all 3 times)but still happins 2...
3 starters in 7 months????? sounds like your getting "riped off!"
find a new garge,,,,if the battery is good and spins the starter over well then my gess is they just "cleaned the starter off" and called it a new one?? the main causes for starter faults is,,,bad battery's,,, not charging the battery up,,,,loose battery leads,,,bad engine earths to car body,,, very tight engine's? or holding the key over trying to start a car with a flat battery and the starter is only just grunting the motor over!
this causes a lot of heat in the starter motor,, and it burns out!
if it happens again fit a new starter with more power like a heavy duty one? but go to a new garge to get the work dont,, and if you can,,,
watch them fit it! but do tell them why you wont to see this starter fitted
Aug 08, 2010 | 2001 Volkswagen Beetle
My 1991 ford f150's battery garge pulses with my blinker blinking
I had this same thing happen to my 1971 dodge demon and what cured the problem was I took a # 10 wire and I ran it from my positive post of the alternator to my positive post on my battery. The reason it does that is that the wires that are used are most common either 14-16 guage and you get a voltage drop due to this.
Mar 07, 2010 | 1991 Ford F150
Screen frozen on ln( won't clear or accept any other buttons.
Try taking out the batteries, include the backup battery if you haven't already. Backup battery is located behind a little door with a screw right above the AAA batteries. Leave all out for a few hours before reassembling. Another problem might be that the backup battery may need to be replace. Hope this helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Calculator
Remote not working
you will need to train (link) the remote to the garage door opener. to do this you will need to find the remote "train" button on the operator.
If you have the manual for the garge door opener this will show you where it is located.
push the train button on the operator, an LED light will start blinking. Then push one of the buttons on the remote. the LED light on the operator will stay on. push the button on the remote again and the light on the operator will turn off.
try the remote it should work now.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garge plms
Press and release learn button on back of motor. Within 20 sec press 4 digits on keypad. Press and hold enter. The light will blink once on the motor. You are done
Feb 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
55 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
