Always I get this message about the password of that corrupt profile when I try to fix it Windows Vista the profile user cannot be loaded.
    Top Expert:
  • Computers & ... Master
  • 22,085 Answers
Go to Safe Mode. Type REGEDIT. Select HKEY LOCALMACHINE. SOFTWARE, MICROSOFT. WINDOWS NT. PROFILE LIST. In PROFILE LIST are two folders with the same name but one has .bak suffix. RENAME the plain one with .ba suffix. Rename the .bak to plain with no suffix. Rename the .ba to suffix .bak. In the now plain one with no suffix, open it and find REF COUNT set it to 0. Open State and set that to 0. Save the files and reboot.
Hope that helps.
Posted on Dec 02, 2014
  • 300 Answers
SOURCE: Dell Inspiron 1420 - says user profile cannot be loaded
Try this, it should work and it really is quite easy to follow -
1. Boot up in Safe Mode. To do this, hit the F8 key while the computer is
booting, and then scroll down to the "Safe Mode" option and press enter. On
my computer the user account icon appeared, but bigger than normal, and I
clicked it and it loaded my desktop in safe mode. It came up with an error
bubble saying that my user account hadn't loaded properly, but I just ignored
this.
2. Click the Start Button and in the white "Start Search" space at the
bottom type "regedit" (without the quotation marks). This will open the
registry editor.
3. In the left-hand pane, navigate by clicking the little triangles next to
the following folders:
HKEY_LOCAL_MACHINE
SOFTWARE
Microsoft
Windows NT
CurrentVersion
ProfileList
You should now have a list of folders all starting with S-1-5- and then a
number.
(You might need to drag the divider between the 2 panes of the window across
so you can read the whole folder name)
Look at the end of each name and you should see one with .bak at the end of
it, and there will be another one above it with exactly the same name but
without .bak at the end.
The one that's got .bak at the end is your old User Profile that Vista has
now made into a backup, and the one without .bak after it is the new empty
User Profile that Vista has created.
Just to check that this is the case, have a look in the right-hand pane for
each of the 2 folders and look at what's written after "ProfileImagePath".
For the folder with .bak at the end it should say C:\Users\ and then your
usual User Account name, and for the one that doesn't have .bak at the end it
should say C:\Users\TEMP.
What you need to do now is to rename the folders in the left-hand pane so
that the one with .bak at the end changes back to being the one containing
your proper User Profile and the new one without .bak at the end becomes the
backup. Do do this follow the next step:
4. Right click on the folder with .bak at the end and then click "rename",
and just change the ".bak" part to ".bk" - i.e. just remove the "a" from the
middle - (this is just to allow you to change the other one to have .bak at
the end). Press enter or click on some blank part of the screen for the
change to take effect.
Then, right click the one that doesn't have .bak at the end and click
"rename". Remove the .bak from the end and press enter or click anywhere on
some blank part of the screen to accept the change.
Then, right click on the one that now has .bk at the end, choose "rename"
and add the "a" back into the middle, so it now has .bak at the end. Press
enter or click on blank park of screen to accept the change.
Close the regedit window.
5. Click the Start Button and then "Restart".
It should work now, otherwise see link below -
http://support.microsoft.com/kb/947242
Posted on May 21, 2008
SOURCE: failed tte logon
when i put on my acer laptop acer 5315 it enter password
Posted on Oct 29, 2008
  • 19 Answers
SOURCE: laptop does not recognize "user Profile" at initial logon
when you are in safemode as administrator you can go to the user section and reset your husbands password. make sure that your caps lock and your numlock is not on. good luck
Posted on Mar 12, 2009
  • 3278 Answers
SOURCE: Gateway T-1620 won't allow me to login. Fains the login, though my password has not been changed
Try installing and running an anti-spyware program, such as SpyBot.
Posted on Jun 24, 2009
perpetually
  • 360 Answers
SOURCE: Service user profile error
Boot into safe mode by spamming the "F8" button "after" you see your VAIO splash screen. You will be presented with a few options, select "safe mode".
When windows loads, you should now have access to your hidden Admin account. I have seen this account password protected and not protected, hit and miss. I would first try leaving the password field blank, then move onto passwords you know.
You can also remove the hard drive and install it into a desktop computer as a slave (extra storage). This will gain you access to all your files. If at anytime during this process you get error messages of "access denied", take "ownership" of the folder you are trying to open.
For the above step:
If your laptop's hard drive is not SATA, you will need a cheap converter to convert the hookup to one that will fit in a desktop. Below is a link to one so you know exactly what you are looking for.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812203012
Hope this helps.
Posted on Sep 15, 2009
Hi, my Acer all in one PC is not accepting my password.
appears something became corrupt in ur user profile.
If u have another admin login use that to try to troubleshoot/fix.
If not try this to gain access
http://www.lostwindowspassword.com/enable-windows-7-default-administrator-account.html
Mar 18, 2015 | Acer Computers & Internet
How fix computer sayin user profile cannot be loaded
Hi Anon
Please follow the instructions in the link below to fix your user profile problem.
Aug 13, 2014 | Microsoft Windows 7 Ultimate for PC
Windows 8 won't come up - only get "personal settings"
Hi HG not sure which personal settings you are referring to but there seems to be a similar posting on Microsoft's site.Personal Settings - Error message stating it failed to load "Personal Settings" Windows Vista
Asked by dweidensaul
06 September 2010
Question
Original Title - Personal Settings
Computer booted. Error message stating it failed to load "Personal Settings". Cannot access personal files/photos/favorites. How do I recover? Answered by Diana D
06 September 2010
Answer
· Was there any change prior to this issue?
Personal files are located under c:\users\<username>\. You may try to access from that location and check.
Step 1: As a work around, perform system restore.
http://windows.microsoft.com/en-US/windows-vista/What-is-System-Restore
Step 2: If that does not resolve, then check in new user account.
Check the link "Create a user account" http://windows.microsoft.com/en-US/windows-vista/Create-a-user-account
If the issue does not persist in new user account do the steps in the following link "Fix a corrupted user profile" http://windows.microsoft.com/en-us/windows-vista/Fix-a-corrupted-user-profile
Diana
Microsoft Answers Support Engineer
Visit our Microsoft Answers Feedback Forum and let us know what you think.
If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster. See the entire conversation on the Microsoft Community website.
Aug 10, 2014 | Computers & Internet
Why does my computer say the user profile service failed the logon
The error has to do with windows not being able to read the user profile for some reason. Always try a restart first if that does not fix it then look at this article from Microsoft on how to fix it. You receive The User Profile Service failed the logon error message
Jul 14, 2014 | Microsoft Windows Vista Ultimate Edition
Packard bell pew91 not accepting password
Rachel its called a corrupted user profile and can be easily fixed. Although these instructions are for Windows 7 they will work with any version of Windows.
http://windows.microsoft.com/en-us/windows/fix-corrupted-user-profile#1TC=windows-7
Online virus removalWindows8Blog
Mar 17, 2014 | Computers & Internet
Dell Vostro 3500 running Windows 7. Trying to log into the admin (only) account and get the message: The User Profile Service service failed the logon. User profile cannot be loaded. No Recovery Media was...
Please check following link from Mocrosoft knowledge base:
Error message: "The User Profile Service failed the logon. User profile cannot be loaded", when logging on to Windows 7 or Windows Vista
http://support.microsoft.com/kb/947215
PS: If it helps then please click on thumbs up.If you need more help then please let me know.
Sep 20, 2011 | Computers & Internet
It says the user profile service service failed the login. User profile cannot be loaded
This message is what windows uses to let you know your desktop profile is corrupt.
There are a few ways to go about fixing.
1) reboot into safe mode, create a new user account.
Here is a Step by Step provided by Microsoft.
http://windows.microsoft.com/en-US/windows-vista/Fix-a-corrupted-user-profile
Apr 02, 2010 | Acer Aspire 5315 Notebook
Vista log in
The user profile seems to have corrupted. The account that you log into is corrupt now may be due to incompatencies or incompatibility or may be a virus or a spyware. Alternatively, you can try logging to safe mode window. As you start the computer keep tapping the F8 key on your keyboard at the sametime. You would reach a screen to choose from different boot options. Select safe mode(you would have to use the arrow keys in your keyboard). Log in with the usual username and password. If it logs in, you might see a black window with large icons. Don't worry. Go go start, control panel, user accounts, and create a new account. So you can use the new account. Restart the computer and login to the new user account. You should be good. Make sure the account you create should be an administrator. Later if you want you can delete the user account that you have been using before. You can delete it from safe mode again by going to control panel, user accounts.
May 26, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
