On the cleaning cycle of my washing machine, the hot water does not en the drum. It is almost as if a valve does not open to allow the water in.
The cycle is meant to clean the drum. First it let some cold water in and then stops to let the hot water in. This does not happen.
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 242 Answers
Sounds like a hot valve fault. call a local repair person, have your make and model number ready when you call.
Posted on Dec 02, 2014
Hot water fills with hot and cold not strictly hot what is the fix
see the causes: and proceed with common sense. God bless you
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the
Sep 22, 2012 | Roper Washing Machines
When trying to wash with hot water only machine fill slows and adds cold water then adds hot this continues until load level is reached and you end up with barely warm water is there any way to fix this...
see the causes and use the common sense. God bless you
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
THERE SEEMS TO BE A PROBLEM WITH LETTING IN WATER, THERE IS AMPLE WATER PRESSURE BUT JUST A TRINKLE IS COMMING THROUGH AND IT TAKES HOURS TO FULL UP TO WASH
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 12, 2011 | Washing Machines
When iput washing on it seems that the hotwater isnt hot the pipes are on ive checked
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on.Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace the Valve.
Nov 30, 2010 | Hotpoint Aquarius WD640 Front Load...
The washing machine won't fill with water at all. we have cleaned the pump valve and we have checked the water lines. are there any other things that could be causing this problem?
You will want to check and make sure the door handle/lock is switching on. the front load unit will not fill with water with the door open. Check that the latch is engaging.
Oct 05, 2010 | GE WSXH208A Front Load Washer
Cold water is not filling machine when place on cold washer cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
WHEN MACHINE IS OFF DOOR IS OPEN TO AIROUT
TWO LIKLY REASONS FOR THIS
1ST IS YOUR APPLIANCE CONNECTED INTO TRAP UNDER SINK IF SO MAKESHORE ITS NOT YOUR WASTE RUNNING BACK TO MACHINE
2ND INLET VALVE IS LEAKING-TO SOLVE THAT A NEW VALVE IS NEEDED
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not allow for hot water
Check the hot valve screen. If clean you will have to verify there is voltage present at the valve when using hot cycle. If there is and the screen is clean then the valve is bad.
Eric
Jul 02, 2009 | Washing Machines
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
