On the cleaning cycle, the hot water does not enter the drum, almost like a valve does not open to let the water in?
Removed the filter/strainer but it was clean. Hose is clear, no obstruction.
    Novelist:
    Scholar:
  • 132 Answers
You have done the basic checks. Check if the wires leading to the solenoid valves are properly connected. These valves are normally installed on the inside of the body where the water pipes enter the machine Please disconnect the electrical power before doing so. After checking, switch on the power and check if water enters the drum. If the problem persist and electrician must check for continuity in the solenoids and to replace it if found faulty. If that checks Ok it is the timer switch causing the problem and need to be replaced.
Posted on Dec 02, 2014
Then the valve is not getting power of its solinoid has failed and gone open circuit
you need to use an ohm meter
isolate the machines supply
and take the top slide/ take the top off {two screws at the rear}
on 10K ohm range
find the red hot water intake valve
disconnect the two plugs connected to it carefully
and connect the ohm meter accross it
it should show around 1K or less/ more
ie if it shows a reading its ok
if not try the 1Mohm range to confirm its gone open circuit
if you get no reading the coil is open
and you need to visit espare or ebay for a replacement {usualy a generic type}
  • 1462 Answers
SOURCE: Intermittent hot water valve not opening
problem may be low water pressure. try putting in a y-piece so cold water is supplied to both valves. only effect will be that wash cycle will be a bit longer
Posted on Mar 31, 2007
zaids
  • 456 Answers
SOURCE: The ?Check ? indicator lamp is flashing, but hoses & filters look good
complicated
Posted on Dec 17, 2007
  • 351 Answers
SOURCE: Asko W660 Quattro Front Load
check the inlet valve solenoid there are three of them one might be o/c,also using to much soap can cause this or a coin stuck in the sump hose near the pump.the filter is in the valve but normally isnt the problem
Posted on Aug 28, 2008
stephanos18
  • 144 Answers
SOURCE: Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Posted on Mar 25, 2009
  • 3230 Answers
SOURCE: water wont drain
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
Good Luck!!
Posted on May 06, 2009
On the cleaning cycle of my washing machine, the hot water does not en the drum. It is almost as if a valve does not open to allow the water in.
sounds like a hot valve fault. call a local repair person, have your make and model number ready when you call.
Dec 02, 2014 | Washing Machines
I just installed a Hamilton whole house humidifier but am not getting enough water to the filter. The solenoid is opening for 2 seconds every minute to release the water as it is suppose to do, but the...
Most humidifiers have a strainer on the inlet side of the solenoid valve, if this strainer is clogged up it will reduce the water flow to the humidifer. Usually sediment builds up in the strainer and all you need to do is remove it and clean it up and reinstall it.
Jan 19, 2011 | General Filters 1099-LH Humidifier
Dishes constantly come out dirty.. What temp should the water be while the dishwasher is running?
Supply water temperature should be above 120 degrees F for effective cleaning. Run hot water from your kitchen sink (your dishwasher should be tapped off the hot water line near your sink faucet) right before you start a dishwashing cycle to make sure it's as hot as it can be when the dishwasher begins filling. Also, during the wash cycle the heating elements at the bottom of the tub may turn on and warm the water further even if you select a "No Heat Dry" option causing a noticeable shot of steam to escape if you open the door during a cycle.
Note: I recently had a problem with our dishwasher (Frigidaire FDB834RFS0) causing dishes to come out dirty and the detergent dispenser to be left with undissolved detergent. Our problem happened to be caused by a partially clogged strainer in the water supply valve. (I would imagine Whirlpool most likely has some kind of filter/strainer in its water valve as well.) When the supply valve was commanded to open for some time, I noticed the water level in the tub would barely be visible below the lower spray arm. After cleaning out the strainer (required removing and disassembling the water supply valve) the water level was noticeably higher -- almost at the bottom of the float or about an inch below the heating elements. Our dishes and the detergent dispenser are now clean.
If your water supply is ok, I would next check to make sure your spray arms do not have any plugged holes and that they rotate freely. Also, use a good quality detergent and a rinse aid. We prefer liquid Cascade and Jet Dry. We have had problems with old, stale, or really thick liquid detergents and by getting a fresh jug have solved the dirty dish dilemma.
Make sure to clean out the filter basket at the bottom of the basin below the lower spray arm occasionally as it can clog and cause the pump to starve due to lack of water. If the pump can't get a supply of water to pump to the spray arms and nozzles, your dishes will not get sprayed evenly and you will end up with them being poorly cleaned.
Hope this helps you out...good luck!
Nov 18, 2010 | Whirlpool Dishwashers
My dishwasher is leaving a residue on plates and plastic containers. I use jet dry and the heating cycle. What could cause the residue?
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Oct 26, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishes are not clean at end of cycle g e g l d 4300l00ww 3 years old
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Aug 31, 2010 | GE Dishwashers
My water supply has little pieces of grit that clog up the strainer in the Price Pfister 548E0BK faucet. I periodically clean out the grit. Recently the water flow rate decreased, and cleaning the strainer...
'DO NOT REMOVE"! lol JUST KIDDING. >You may need to remove again to find out why the valve seat is not sealing In fact, expect that you will. The grit is white in color? did you see any special washers or seals in the DNR zone? wHEN REINSTALLING THE VALE BODY, YHE STEM SHOULD BE ALL THE WAY OPEN . cLOSE THE VALVE ONLY AFTER ALL IS IN PLACE. AND YOU NEED An INLINE STRAINER IN YOUR WATER SYSTEM.. gOOD lUCK _nED_
Sep 27, 2009 | Price Pfister 548E0BK Catalina...
Our frigidaire Galley front loader washer has an odor all the time even after washing in hot water...any suggestions?
Most odor problems can be traced to mildew or mold in the creases and folds of the bellows seal and the pump strainer. This is the seal that you see when the door is opened and connects to the drum.
There are chemicals available that can be placed in the washer. I've seen them advertised on YouTube (type in smelly washer), but I cannot vouch for them.
Some people report that they have been advised to leave the door open when the washer is not in use, and I've seen others recommend Tilex.
What works best, in my opinion is a thorough cleaning, including the strainer. Here's how:
Gain access to the strainer. It is located behind the front panel, at the bottom. The strainer is in-line between the drum and the pump, and is connected to the drum with a rubber hose. Open and clean the strainer. Look up into the pump cavity and remove/kill any debris in there as well. Reassemble the strainer, putting a spray of silicone on the "O" ring and threads. Wipe down the bellows seal with a solution of bleach and soapy water, getting all of the grooves and nooks wetted. Let it sit for 5 minutes, and wipe it again. Pour 1 cup of bleach in the washer. Fill the dispensers (detergent, bleach and softener) with bleach. Run a "sanitary" extended cycle with the hottest water on the wash cycle and rinse cycle. When this cycle is completed, run another cycle to flush all bleach residue out. Clean the seal with the bleach/soapy water 1X/week, or as your nose tells you.
Hope that you have found this to be helpful.
Best regards, --W/D--
Aug 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Does a maytag model mah2400a have a drain filter i have a sour smell an have tried vinager bleech and baking soda nothing has worked any suggestions
It has a strainer. These strainers are evidently designed to make washers stink. Your strainer is located behind the kick panel, below the main panel. The strainer is located between the drum and the pump. It is connected to the drum with a rubber hose. Unplug your washer. Pull and clean the strainer, While the strainer is open, look up into the pump suction cavity and remove any loose debris that you see in there. Reassemble the strainer, replace the kick panel.
Clean the door seal face with a bleachy water solution, let it sit, and wipe it down again. You want to get the solution into the grooves behind the seal face, and wherever you think mold and mildew might be on/in/behind the bellows seal.
Put one cup of bleach directly into the washer tub.
Fill all of the dispenser cups with bleach.
Run the washer on your hottest setting (no clothes). I use the sanitary setting with an extended wash.
When the cycle is finished, run another cycle with nothing in the dispenser cups or tub, Just plain hot water, this will flush out the bleach residue. Most folks wipe their bellows seal face and grooves down with bleachy water regularly. (1X / wk).
Hope this helps. Best regards, --W/D--
Aug 10, 2009 | Maytag Washing Machines
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Water not entering machine for rinse
    if the right temp water enters the machine on other cycles...it's most likely the timer...if you have trouble getting water into the machine, it's the water valves (they are actually electric solinoids) one for hot and one for cold)  also try another rinse setting on the dial.
    Mar 22, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
