Question about Kodak Scan Station 500 Network Scanner 8738056
We received a Kodak Scan station 500 from a client that is not feeding the pages through the scanner. It does however pull through the pages if I pull back on the leaver of the separation module.
We received a Kodak Scan station 500 from a client that is not feeding the pages through the scanner. It does however pull through the pages if I pull back on the leaver of the separation module. I have replaced the module as well but it still gives the same problem. Any suggestions?
  • 8 Answers
SOURCE: i280 won't scan!
ImageCalibration means the cameras don't get enough light during their self test.
Please check the following points:
Are both lamps on or one lamp in case you have a single page scanner?
Are the imaging guides (the clear sheets above the cameras) clean?
Are the little white tags on the imaging guides present?
One tag on each imaging guide.
Without this small white tags the cameras are not able to check themself.
For emergency you can apply a small white paper or white insulating tape instead of missing tags to test the scanner.
If the lamps are light, both tags are present please calibrate the scanner with the kodak calibration sheets. You will find the calibration menue in the scanner validation tool. You can get this tool from the Kodak home page.
Posted on Jul 15, 2008
  • 14 Answers
SOURCE: Kodak DS3500 scanner
Are you using a Kofax SCSI card or an normal SCSI controller like Adaptec?
By using a normal SCSI controller, is there an ASPI driver problem after a WIN XP update? After an update check the ASPI dlls in \sytem32. They should be version 4.71 or higher.
Check the SCSI connector pins and the terminator.
If available change the cable.
Scanner check:
Is the green lamp (Ready) on or is the red lamp (Error) on?
- green lamp on:
the internal self test is ok, but the internal SCSI interface may possibly faulty.
- red lamp on:
the internal selftest detect an error.
It's possible that the DC/DC power board, the CPU board or the power supply inside the scanner is defective.
After reassembling the front side camera you will see at the bottom a PCA board with some LEDs whitch indicate by red light the different voltages when power is on. You find the different voltages printed at the PCA close to the LEDs.
In case on or more LEDs don't shine the according DC/DC transformer on the PCA is defective.
Futher you see LEDs at the camera PCAs. They should be on too.
In case the CPU board has an defect you must have an special Kodak activation tool to unlock an new or used CPU board after exchange.
Posted on Jul 18, 2008
  • 7 Answers
SOURCE: Kodak 3520D scanner Front Scan Mod gain issue
Lamp need to be replace and re-calibrate.
Posted on Jul 20, 2009
SOURCE: I have a Kodak i40 scanner and it does not feed
This may help. The scanner has a pad assembley which needs to be replaced once it has worn out. If you open the top of the scanner using the button on the left hand side then on the part that open upwards you will see a pad about an inch in lengh with two clips either side. This pad should be about 4 - 5 mm in thickness if it is less then that then paper just files through. You can get the replacment pad from companies on the internet.
Hope this helps
Raph
Posted on Oct 13, 2009
SOURCE: Kodak i260 Scanner
All of a sudden I am getting a double-image when scanning a document. The first part of the image has been moved to the left about 2 inches and the second image on it starts about 4 inches down and about 4 inches from the left. So weird. Any ideas of what could be wrong?
Posted on Apr 06, 2011
What will be the reason for canon sensys fax-L 150 coping dark page but faxing and printing is ok.
First things first. Try and print report from the fax. Any kind of report. If it is printing OK, then the next step is to check if:
Your clients receive your faxes OK? If they are dark as well, then your scanner head is at fault.
When you make Copy on your fax and it prints dark it could be simply set with dark settings _or_because of the white calibration strip or roller being soiled or dirty, which acts as the ultimate white reference point for scanner _or_ the Scanner CCD sensor is in paper jam release position (too far away from reading the originals) just pull it back to normal feed position.
Or simply faulty scanner.
Sep 30, 2016 | Canon i-SENSYS FAX-L150 Laser...
How can I share Kodak i2400 on Lan?
It is not possible, unfortunately. I would love to read this article you referenced. There are many services, resources, and registry issues that come into play. As an alternative, Kodak produced the Scan Station 500/700 for this very reason. Cheers!
Dec 16, 2014 | Kodak ESP 3 Multifunction Printer/ Copier/...
I2400 scan to email doesn't work
You must have an email program like Outlook installed on your computer. When scan to email is selected it simply opens whatever defaul email client and attaches the scanned doc to a new email message.
Sep 24, 2014 | Kodak i2400 - document scanner
Kodak instruction manuals
The user manuals are all on the web go to kodak.com
Jul 25, 2014 | Kodak Scanners Kodak I730 Sheetfed Scanner...
How to unlock a Kodak Scan Station 100
There is no procedure to re-image or format the drive. You must purchase a mail in repair from Kodak: Contact 1-800-822-1414 for service.
Feb 13, 2014 | Kodak Office Equipment & Supplies
How to turn off or turn down volume on start-up/shut down of the Kodak Scan Station 500
Sorry if this double-posts. From the configuration organizer, go to settings-->device and scroll down to language. Make your changes, save the config file, and upload to the scanner
I also found the kodak youtube series to be really helpful with basic config questions. http://www.youtube.com/watch?v=qQyI-VHFwqU
Dec 31, 2012 | Kodak Scan Station 500 Network Scanner
DR-7580
About 99% of the time, there is something stuck on the lens. Our clients that use these are hard to convince of this, but often if you take a small flashlight, you can either find something stuck on one of the lenses or there's a scratch on one. If it's scratched, you're out of luck and will have to replace it. Otherwise, use a light alcohol based pad and clean with it wrapped around your fingernail. Kodak scanner cleaning supplies work great.
Aug 07, 2008 | Canon DR-7580
Kodak i40 Front loading scan
Try downloading the latest Firmware for the Kodak i40 Scanner at the following Kodak.com page: http://graphics.kodak.com/docimaging/US/en/Products/Document_Scanners/Desktop/i40_Scanner/Support/Drivers_And_Downloads/i30_and_i40_Scanner_Firmware/index.htm
Follow the instructions carefully, and make sure that the scanner and the PC DO NOT turn off while doing the Firmware update. I recomend connecting both to a UPS with a known good battery while doing this upgrade.
This should install the latest features including the one that enables front feed.
Otaron
Jun 02, 2008 | Kodak i40 Path-Through Scanner
Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Apr 28, 2008 | Kodak i40 Path-Through Scanner
Kodak Scan Station 500 Network Scanner 8738056 Logo
52 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
