Question about Microwave Ovens
Does my hp model CO56-219WM have an internal fuse? When i plug it in.. it does absolutely nothing
    Top Expert:
  • Microwave Ovens Master
  • 74,459 Answers
Surely there should be a fuse with this device. But, if the fuse should blow up, there will be a reason. Line voltage spike, overload, shorted component/s inside the device etc: Without getting an exact reason for the fuse blow, never insert a fuse and switch ON the device. It might make things worse. Contact any service technician. Electro help
Posted on Dec 02, 2014
Lg grill wavedom model no MG-6644B
It all depends which fuse is it the plug fuse as used in the UK or the internal fuse? If it the internal fuse either the magnatron has gone S/C or the high voltage rectifiers have gone S/C and will need replacing the the indentical components
Aug 31, 2014 | Microwave Ovens
Model #MW89925B No power at all. Unplugged for a while, plugged back in, still nothing. Fixable or time for new microwave? Manufactured in May 2007. Thanks
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 07, 2011 | Emerson Microwave Ovens
Have a Sunbeam-Oster Bread Maker Model 4810, Style BB-100. I haven't used it in awhile and when I plugged it in there is nothing showing in the display. Pressing the "Start" button also yields...
open the unit and check for an internal glass fuse on the control board,sometimes when they sit for a period of time the fuse wire deteriorates and breaks or by the initial current surge it can burn thru too
Jan 07, 2011 | Sunbeam Microwave Ovens
The microwave is absolutely dead as if getting no power - circuit breaker is OK. Died suddenly...just nothing there when tried to use.
Possibly the internal fuse. Unplug unit, remove all case screws on the back of the micro. Slide the case toward the back and remove. Look for a glass tube type fuse, simular to automotive fuses of the past. It should be located near the controls. If bad, I have been able to find replacements at Radio Shack. If the fuse is good, I'm sorry, it's beyond my microwave knowledge level.
Jan 03, 2010 | Sharp R-1460 Microwave Oven
GE Microwave JVM1870SK03-NO POWER TO UNIT, PANEL DISPLAYS ARE ALL BLACK, CIRCUIT BREAKER NOT TRIPPED. The oven was actually working, then suddenly in the middle of warming the food, it did quit -...
change the units internal ceramic fuse and try this,may just be a fuse or if new one blows then could be h.v. diode.capacitor,thermal fuse,magnetron tube
Nov 09, 2009 | GE JVM1190 Microwave Oven
I have taken the microwave oven out of the box. I have plug the equipment into the mains supply. Absolutely nothing happens. Mains supply o.K. Main 13 amp fuse O.K. Is it me or is this equipment u.s.
If your sure that the socket you are plugging it in to (try something alse in it) is ok and the fuse in the microwave plug is ok and the microwave is not powering up at all then take it back to where you bought it for an exchange.
hope this helps.
Iain
Oct 15, 2009 | Microwave Ovens
Microwave just stopped working
  • Internal fuse may have opened
  • Door interlock may have failed
  • Magnetron may have failed
  • Control panel may have failed
Jun 19, 2017 | Sharp R-1492 Microwave Oven
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
My goldstar microwave stoped working. No display, its dead. Is their an internal fuse and where is it located. Thanks
You may have a blown internal fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Feb 28, 2008 | Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
