Question about GE Dishwashers
WHAT DO YOU DO ABOUT A DISHWASHER THAT TAKES WATER IN AND THEN IMMEDIATELY DRAINS THE WATER OUT?
Have checked the buttons to make sure that all are pushed in correctly. Check the water flow. The dishwasher does run through the cycle but no water gets on the dishes or the soap.
    Top Expert:
  • GE Master
  • 75,178 Answers
Contact the authorized service centre for GE dishwashers. It will be the best. There are many reason for this type of fault can occur. No-one can exactly predict, what it will be.
Posted on Dec 02, 2014
How do I fix my Danby Dishwasher? It fills with water then immediately drains.
Most likely the flood switch is triggered. This causes the pump to operate as soon as you start it. Check if the float at the base comes up when you press it by hand. If not the float spring might be stuck and pressing the flood switch underneath.
Sep 01, 2014 | Danby DDW1809W Builtin Dishwasher
How to reset Whirlpool dishwasher ADP 6342; it stopped working and cancel button is blinking 8 times
F8 failure (slow/no draining)
In a consumer cycle, the appliance is indicating F8 E1 (slow/no draining). This is because of wrong signals from the circulation pump read by the control board and interpreted as "water present", when there is no water. During draining (and in fact, there is no water), the failure occurs.
1. Check if drain hose is not closed/clogged
2. Drain pump faulty, harness or wiring faulty, control board faulty
3. If machine is equipped with OWl, issue might be caused by damaged or dirty OWl. Clean the sensor lenses then , if issue is not solved, replace OWI (optical water indicator).
Dado
Jun 14, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
Water not draining
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will notdrain out
heatman101
Mar 26, 2011 | Dishwashers
Water drains out bottom immediately as it fills?
you have to check you drain hose, it sounds like you have lost your vaccum break
make sure the loop from the drain hose goes above the machie top before running into the drain
Oct 22, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishawasher drains but right after lets all the
The check valve might be stuck. The valve is supposed to let the water out but stop it from flowing back in. Also make sure you discharge line has a loop. And check your air gap at the sink(if you have one) and make sure it is not plugged.
Aug 04, 2009 | GE HDA3500NWW Dishwasher
No water sprays after resetting an F2 fucntion problem
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
May 29, 2009 | Asko D1776 Stainless Steel Built-in...
Dishwasher Accumulates Water When Off
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
Nov 08, 2007 | Bosch 24 in. SGS43C12 Classixx...
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwashers Logo
54 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
