Question about Drills
My drill press motor runs fine, belts don't slip, and the chuck spins just like it should until I try to drill a hole. Then the bit stops, but everything else still works like it should. The belts are
I can't find this drill press on the internet. Magnum is the only name I can find on the machine. There must be something wrong between the belt pulley and the chuck.
  • Alan Doner
    Alan Doner Dec 02, 2014
    Belts are not slipping
  • 46 Answers
Your drill spindal might be freewilling, if it is your not ingaiging the drive. Some drill presses have a locking switch and or lever to ingage to make this work.
Posted on Dec 05, 2014
  • 22 Answers
SOURCE: press stops under even slight pressure on drill
adjust tension on pully or the belt may be worn or streched replace belt.
Posted on Dec 13, 2008
wireguy212
  • 1627 Answers
SOURCE: My bench drill press chuck will jam while
I used high strength loctite on mine and it never slipped afterword.Just don't get any in the moving parts of the jaws.
Posted on May 19, 2010
puertobori
  • 7733 Answers
SOURCE: I have an old Delta D-220 drill press. While the
You are right,but if the wobble is not too big to do drill jobs it can be used.Sometimes drill jobs need to be precise,so the you will need it just aligned.
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or go direct to this link.
Good price and service.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
SOURCE: My Powermatic drill press model
Hi, this is happening because the belts are shinny... true.. well and a little stretched... you see what happens is the belts are slipping over the Pulleys when the drill bit draws and bites on it hard.. the Fix if you will, is to A: Replace the belt... Or B: Tighten the belt, & roughen up BOTH surfaces a little to improve traction..
This usually will only be a stop gap measure though, as this really means that you need a new Drive Belt(s) as the existing one(s) has stretched too much, and has lost it's grip. belts only have to increase their size minutely to just loose that edge that a newer one has.
Posted on Nov 25, 2010
  • 11 Answers
SOURCE: Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Posted on Mar 18, 2011
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
How to get my ignition lock out
Instructions
Test fit a drill bit in the lock cylinder. You want a bit that is just smaller than the cylinder. You will be using hardened drill bits to cut through the cylinder, since ordinary bits may be damaged by drilling metal.
Lock the drill bit into the drill chuck and tighten the chuck.
production in very fast delivery! special threading taps, plug gauge
Drill a starter groove into the lock cylinder. Start the drill on a low speed and create a groove in the end of the lock cylinder. You don't need to create a deep hole, just enough of a groove so that the drill bit will not slip on a higher speed.
Increase the drill speed to the highest setting and drill out the lock cylinder. Let the drill do the work. If you force the drill into the lock cylinder, you could burn out the rotor inside the drill motor
Jul 10, 2012 | 1999 Pontiac Sunfire
Drill runs until pressure is applied to the bit. then the motor cotinues to run but the chuck stops spinning.
It sounds like the gears themself are stripped. On the inside of the drill right behind the head is a gear that turns the head itself. When that gear is stripped the head will spin sometimes withou pressure but when pressure is applied the head will not spin
Jun 16, 2012 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drilling wood on a craftsman 10" drill press
There are several possibilities. I am assuming that by "hang up" you mean that the motor still runs, but the arbor, chuck, and bit all stall. I also assume that you are running the bit up and down to clear out the wood shavings from the bit out of the hole, you are using the correct amount of downward force, and that the bit is sharp. I would first check to see that there is proper tension on the drive belt. You can add a belt spray designed to increase friction for better running. I would also gear down the drill press even more to increase torque (I know you say you are running at the correct speed, but try a reduced speed). Another method is to use an auger bit or a forstner bit without pilot holes. If you are using a spade bit, you might try no pilot hole, and drill at a faster speed. I have a junk 10" drill press and have no trouble drilling 1" holes in oak.
Sep 14, 2017 | Craftsman Drills
My bench drill press chuck will jam while drilling, The belts are tight. It actually spins inside the tapered shaft, The belts do not slip. Any suggestions?
May 19, 2010 | Drills
I am using a Delta 17-950L drill press that when I use a 2" Forster bit the spindle stops. drill press is new and have cut approximately 100 2" holes. thought that the bit was dull so I purchased a new bit...
This sounds like a belt tension problem. If the motor pulley is still spinning but the spindle pulley is stopped try increasing the tension on the belts.
If both the pulleys slow down or stop together, then try reducing the spindle speed to give it more torque under load.
Dec 13, 2009 | Dewalt Delta 17 950L 16.5" Twinlaser...
Having problems securing masonary Bit on 3/8 Black&Decker Drill 7
If it's an inexpensive bit, odds are it's spinning in the chuck. If the chuck key can't tighten the jaws well enough, you'll need to borrow or buy a different drill (or you could replace the chuck).
If you bought an SDS bit (one with slots milled in the shank), you're best off buying a bit made for a standard drill. It's not impossible to get a SDS bit to chuck into a standard drill, but it's difficult and they often slip loose during drilling, messing up the hole.
Take care!
May 24, 2009 | Black & Decker Drills
Press stops under even slight pressure on drill
Nov 15, 2008 | Drills
Drills Logo
272 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
