Sony Cyber-shot  DSC-W90 Digital Camera
Problem for Sony Cyber-shot DSC-W90 Digital Camera
Dsc-w90
By hectorg511 on Nov 11, 2007
when i turn on the camera the lens goes in and out about 3 times then i get this warning that says "turn the power off adn on again". I can't take any pictures what do i do?
Same Problem
May 03, 2009
-   I bought a new non Sony battery and the same message appeared. Happen to find this page on the web and your suggestion. Was skeptical, but did the smacking anyway, SURPRISE - it worked just like new.
Thanks for the help! -   barbtaylored
Apr 23, 2009
-   Same problem- smackey no fixey. Camera's a piece o' crappy. -   Guest
Apr 11, 2009
-   Identical problem. turn camera on, the lens goes in and out three times and then the message to turn the camera off and on. just got through "chatting" with sony. he says it may be because we bought a non-sony battery (we bought a Digipower replacement for the Sony OEM battery). we tried resetting the camer and reinitializing it but to no avail. so we're now going to have to spend another $40+ on another battery (this time a Sony) with NO guarantee that it will solve the problem. frankly, i'm surprised that with so many postings of this problem, Sony has NO idea what the problem could be. if they KNOW its the battery, then just say so. Have others had this problem after you replaced the Sony battery with something else? If so, the tech knew nothing and i'm going to have to spend $111 to fix it. -   arnosrat
Mar 14, 2009
-   it keeps going in and out and tehn makes me turn it off. but it doesnt do anything. i can look at my pictures but not take any new ones. wtf-   keigger
Feb 27, 2009
-   I have the same problem where the lens goes in and out 3 times and then it tells me to turn the camera off and back on again. I tried the "smacking" technique but it did not work. Does anyone know why this didnt work or anything else that I can do to fix this problem?-   buffhornet19
Best Solution
posted on Sep 14, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
damn, I read this and I was like "that kinda sounds retarded, but anything is better than this, so it won't hurt to give it a try"
5 seconds later, it works
so yeah, this method actually works
Thanks
Solution #2
posted on Aug 22, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks mate!!! This worked well. Hopefully it will last.
Solution #3
posted on Jul 28, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Damn in it worked! My camera is as good as new!!! =)
Solution #4
posted on Nov 11, 2007
Helpful)
AMCViet
Rank: Master
Rating: 86%, 45 votes
this is a very simple solution. i have researched and looked for this solution in the past and works very well.
  1. you will need to turn off the camera and hold the camera on the edges in a way that you wouild hold a pack of cards
  2. you will "smack", or "pack" on all sides besides the side that has the buttons. carefull to hold it steady and not too tight that you would squeeze the lens or LCD screen on the back.
  3. this will cause it to resync in.
this method is very silly but works 100% of the time due to the fact its like smacking a old television back in the day as if you were trying to get better reception.
let me know about this
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #5
posted on Jul 06, 2009
Somewhat Helpful)
ericaction
Rank: Apprentice
Rating: 75%, 1 votes
I tried the smacking solution and it didn't work for me. What did fix my problem, was to turn on the camera, wait for the message to appear, then open the battery compartment and take out the battery out while the camera was still on. I then put the battery back in, turned my camera on and it worked. Hopefully this works for somebody else
Was this helpful?
Yes
No
Solution #6
posted on Mar 06, 2009
Somewhat Helpful)
reefland
Rank: Apprentice
I wasn't able to fix it with the suggesting smacking.
However, I can get it working if I keep turning the mode selector dial over and over while the lens keeps going in and out. I'm finding 90% of the time I can get the camera to kick in and start working. Set it back to the auto mode (green camera icon) and it works fine until I turn the power off again.
Was this helpful?
Yes
No
Solution #7
posted on Nov 03, 2008
Somewhat Helpful)
jhiu
Rank: Apprentice
great i am from colombia i take the camera to a technician and he was worried about opening the camera, so he game me it back with no solution, then i realized of this web page and i got this simple but useful solution...... great my camera is working again thanks a lot....
Was this helpful?
Yes
No
Solution #8
posted on Aug 24, 2009
Not Rated)
hazynu22
Rank: Apprentice
Rating: 0%, 0 votes
So, I tried all the suggestions on this post. I smacked it, I removed the battery while the lens was moving, and I moved the program dial around, but nothing worked.
Here's what worked though.. With the camera off, and the lens retracted, I pushed down on the lens with my thumb, going in circles around the lens. That did it and now it works!
Was this helpful?
Yes
No
Solution #9
posted on Jun 28, 2009
Not Rated)
DiyAtHome
Rank: Apprentice
Rating: 0%, 0 votes
It worked for me too!
Just saved $110. Thanks si nycg!
Was this helpful?
Yes
No
Solution #10
posted on Jan 24, 2009
Not Rated)
ruthyfr
Rank: Apprentice
Rating: 0%, 0 votes
thank you, it worked!
Was this helpful?
Yes
No
Solution #11
posted on Oct 20, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It worked for me!!! Thanks!
Popular Solutions for Sony Cyber-shot DSC-W90
Questions and Unsolved Problems for Sony Cyber-shot DSC-W90
Do you recommend Sony Cyber-shot DSC-W90 Digital Camera?
Answer
Answer
Sony Cyber-shot DSC-W90 Digital Camera will not zoom. When I try to use the zoom button, it does... (More)
Answer
still images are often blurry and pictures are grainy.
Answer
my sony cyber-shot DSC-W90 has the error E:91:01 and is starting to take blurry pictures
13 Other Users Have The Same Problem - Continued
Comment by little_mi269, posted on Feb 21, 2009
i have tried hector's remedy but to no avail. the lens sounds as if it is stuck. help.
Comment by Guest, posted on Jan 12, 2009
Comment by Guest, posted on Dec 10, 2008
Oddly enough if worked for me too, hilarious. Thanks
Comment by alimoo, posted on Nov 14, 2008
when i turn on the camera the lens goes in and out about three or four times and then the camera says "turn off and turn on again", but it still doesn't work, so i can't take pictures.
Comment by tomdesim1, posted on Oct 26, 2008
When the battery died the lens was out. With the full charged battery the lens doesn't go back in and the camera says to turn power back off....I keep powering on and off but no change, lens is still stuck.
Comment by mattyksa, posted on Oct 03, 2008
When switching on the camera as the lens extends there is a sound like gears grating, and the same problem as above
Comment by savagewind, posted on Aug 12, 2008
I have the same problerm turn camera on lens goes in and out 3 times than the error message turn camera off than on
Comment by Alix881, posted on May 25, 2008
hi, for some reason when i turn my camera on the lcd screen is completly black. i can sitll take pictures and view them though. whats wrong? why does the screen work when i view pictures but not as im taking  the pictures?
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in , IL
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
