Question about Dryers
How to wire admiral dryer ADE7000AYW with 2 wires
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 88 Answers
If you're trying to plug a 3 prong connector into a 2 prong outlet you'd be safer to convert the outlet to a 3 prong (grounded) outlet. Otherwise, if you're feeling ornery, you can just break the 3rd prong off of the plug and plug it right in. They also make a 3 prong to 2 prong adapter that you can get at any hardware store.
Posted on Dec 04, 2014
How to rewire my admiral dryer from 3 wires to 2 wires 240v
Your 3 wire cable should have 1 live, 1 neutral and 1 earth or ground. I don't see why the dryer has 2 wire setup. Unless you are seeing where the ground goes? Get an appliance engineer to check it or get an owners handbook. Don't take chances with electricity.
Dec 05, 2014 | Admiral Dryers
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Admiral dyer model ade7000ayw wont make heat
You will need to replace the heating element and the thermostat. They come in a kit and is a simple job to replace them. Here is a link to the kit.
Oct 14, 2012 | Admiral Dryers
I'm trying to install a 4-wire system electrical
Hi heathvaneato...
Go to the following webpage and you will see a picture and description of how to wire your dryer.
Please take time to rate me thumbs up.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.ph
Sep 23, 2011 | Admiral AED4475TQ
I have a maytag admiral dryer (ade7000ayw) stopped working over tonight? It's plugged in and the outlet has power.
The thermal fuse is what the problem very likely is. It is located on the side of the heater housing on the upper part of the back wall of rear drum support. To check it UNPLUG DRYER,remove the 2 white wires on the right side of where the heat element goes and check the thermal fuse for continuty (zero ohms resistiance) using a meter set to measure ohms of resistiance
Aug 12, 2011 | Dryers
ADMIRAL ADE7000AYW This dryer will not start at all. Light inside is not on. There is power at the plug. Is there a internal breaker
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 18, 2011 | Dryers
How to clean the front lint duct on Maytag Admiral ADE7000AYW
I'm not sure if the front lint duct is like a frigidaire. But there should be a couple of screws that can be removed. Then you should be able to remove the cover. This should give you access to the inside duct and you will be able to clean it out.
Jun 03, 2009 | Maytag Dryers
Dryer heats but takes a long time to dry
Hello Jeff,
You may have a bad overtemp switch that is disabling the dryer heating element ( normally as a safety mechanism to keep it from over-heating and/or causing a fire) from staying on. Many ( but not all) are of the auto reset type and open the circuit if they are sensing high temperatures. When they sense this over temp condition , they open and disable the heater element from being energized. Once the temp drops to less than their limit, they reset and allow the heater to switch on. That would be one consideration to investigate. If you can gain acess to te back of the dryer, you can bypass these switches by shortng the wire leads together.. Do this as a diagnostic only.. and DO NOT leave them that way.. you risk having a fire if you do.. also.. make sure you remove or disable power to your dryer when you are checking this out. If the dryer heater remains on after you short the temp switch leads together, then you wil have proven that the temp switch is the problem and it shoul dbe replaced..Hope this helps you...
Sep 18, 2008 | Dryers
Dryer not starting
Dryer needs a new motor. I changed the thermal fuse and the dryer worked for a minute then stopped without the ability to restart.
Jul 05, 2008 | Dryers
How to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
May 21, 2008 | Dryers
Dryers Logo
Top Dryers Experts
