Question about HP Office Equipment & Supplies
I use the HP Officejet-4632 to print shipping labels for my business. It used to work great, but after about every 25-30 prints there is a paper jam due to the large rubber wheels shedding and not ful
I mainly print on Avery shipping labels-8126, which have a wax backside. This combined with the deteriorating rubber on the large grabbing wheels seems to be the core issue. Any advice would be greatly appreciated.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Replace the wheels or do less copies at a time. You could but a new one too.
Posted on Dec 02, 2014
SOURCE: hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Apr 01, 2008
  • 138 Answers
SOURCE: Brother 5250 DN Paper Jams
You problem is actually in the pick-up roller and separation pad areas. the paper is delaying and not making it through to the next check point in the machine fast enough.
1st
Take it by your closest Brother Service Outlet. They're in the phonebook under "Computer Service & Repair". It's a cheap fix but requires parts.
2nd
Use good paper. Paying a little more for paper will save you a lot over time in repairs and premature toner and drum failures. Brother printers are really finicky about paper quality. Recommend "HP Office" brand paper as a minimum. It's a known good paper for general everyday printing and won't break the bank.
Posted on Aug 26, 2008
  • 461 Answers
SOURCE: I am trying to print
Does it still print on plain paper? Check to see if you are missing one or more labels as they may have come off and onto a roller or other part. I've found that label sheets with any labels removed prior to printing are always prone to loosing labels in the process of traveling through the printer.
Posted on Dec 07, 2008
  • 3 Answers
SOURCE: printer grabbing the paper very rough, jamming inside
CHANGE YOUR PRINTER DEFAULT
Posted on Mar 01, 2009
SOURCE: Avery label printing alignment issues. Please Help!
you may need to use some free software that is available for 10.4 and 10.5 users. produced by avery it is the DESIGN PRO available for download at http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-Mac.htm
also available for PC
a bit awkward to learn, it does the advertised job
Posted on Aug 18, 2009
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
When printing labels (Avery 5160) the labels start being shredded half way through and then the printer jams.
Have you setted up in the printer driver to print on label? the printer will automatically adjust the internal parts for printing on a higher density paper!
If you done it gently remove the Duplexer unit from the behind of the printer and chech for pieces of paper or everything could cause the paper jam!
Hope you found it useful, for futher questions i'm here :)
Dec 07, 2015 | HP Officejet Pro 8610 Inkjet Multifunction...
Paper keep jamming
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 29, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer carriage jam and then locks
Dec 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
The problem is cartridge error.I cannot print.what will i do?
Nov 24, 2010 | HP Officejet 4355 All-In-One InkJet...
My printer says papaer jam but i don't see any paper in it
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 24, 2010 | HP Officejet 5610 All-In-One InkJet...
Our HP Office Jet Pro 8500 printer has a message stating there is a paper jam when there is no paper jam. How can this be fixed?
Check the following Steps for fix Hp printer carriage Jam :
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Carriage jam. what should I do i can not problem
Check the following steps for solve Hp paper jam :
Sep 13, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
111 people viewed this question
Seeker5211
Seeker5211
