Always detects the network but won't connect
Your router might have not enough signal strength output; or not configured well to synchronized with your Sharp TV.
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to
resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
