Question about Car Audio & Video
How do I fix my m-770 amplifier fromm blowing the 6.3A 125v fuse
Replacing the fuse five times trying different plugins through out the house.
  • Car Audio & ... Master
  • 5,480 Answers
There could be a short in one of the wires or within the amplifier itself! Check the speaker wiring first!
Posted on Dec 02, 2014
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
How do I fix my home audio pioneer amplifier from blowing the 6.3Amp fuse
If it does blows off fuse; as soon as it is switched ON; either its mains rectifier section circuit; or its audio output section circuit will have any kind of short circuit. Contact any service technician. Your set need a though check-up. Never insert a fuse, and check further; till the fault has been rectified. It might make things worse.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 02, 2014 | Pioneer Car Audio & Video
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
Apr 18, 2013 | Ricoh Aficio 450 Copier
I'm trying to fix my Viewsonic N4825P. I have narrowed it down to the power supply since every time I replace the fuse and plug in the tv, the fuse blows. The fuses I am using are 5A 125V. Do I need t
I would suggest trying what is called a slow burn fuse of the same size, if there is something wrong with the power suppy then the fuse will continue to blow I would not recomend a higher amp fuse as this may cause other things to fry in unit.
Nov 13, 2012 | Televison & Video
My JVC 100 watt amp blew a fuse 125v - 6.3a. is there and alternate replacement fuse?
You can buy replacement 6.3 amp fuses at Radio Shack, but in a pinch you can substitute a 6.5 amp fuse. It's only slightly higher in value, so it will still blow soon enough if there's a problem.
However, this doesn't answer the question of why the original fuse blew. Fuses very seldom "just go bad", so before you start replacing a blown one you should find out what went wrong. Check the power supply rectifier diodes and filter capacitors for shorts. They sometimes break down with age or because of power line surges. Also look for shorted output IC's or transistors. If you can't do this yourself, see if any of your friends have experience servicing or let a professional fix it.
Please, don't just stick in larger fuses (or worse, wrap foil around them) when they blow. Many times I've seen what would have been a simple repair turned into scrap that way. Hope this has helped, and thanks for using Fixya!
Nov 08, 2010 | JVC Audio Players & Recorders
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Home Amp fuse keeps blowing
This usually happens when there is a problem with the main power supply and is relatively rare. If you can post the make and model, I can give you some things to check if you are somewhat familiar with electronics.
Thanks,
Dan
Feb 19, 2009 | Pioneer Audio Players & Recorders
Pioneer m-770 will not turn on
you probably have a short in the circuit some where. you need to replace the transistor and look at all the solder joints to make sure there not damaged or cracked. i have the same amplifier and i replaced the fuse several times and it blew every time up until the last time when the 4 of the power output transistors blew. what ever you do do not try and power it on till you do all the things i told you or you will have sparks and fire. my mistake cost me my amplifier. but might help you get yours repaired
Dec 24, 2007 | Audio Players & Recorders
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
