Question about Brother MFC-J470DW Inkjet Multifunction Printer - Color - Plain Paper Print - Desktop Copier/Fax/Printer/Scanner - 35 ppm Mono/27 ppm Color Print - 12 ppm Mono/10 ppm Color Print ISO - 12 ipm Mono/10 ipm Color Print ISO - 1200 x 6000 dpi Print cpm Mono/5 cpm
My printer won't print its sending blank papers through.
Removed try, put it back, checked the rollers and tried to look in the scaner compartment for jammed papers.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
The ink/toner is probably out. Do you have the correct drivers for the device also?
Posted on Dec 02, 2014
  • Yonah Abongo
    Yonah Abongo Dec 02, 2014
    The toner was full, think twas just corrupt applications jamming it. Have cleaned and sorted it out
  • Anonymous May 08, 2015
    maybe time to contact a professional that you used to contact all the time for computer work?
Errors with my Printer/scaner
Jessica:
This could be one of a few things... First, Windows 8 is a completely different animal from Windows XP! Try reloading your printer driver in Windows 8. If this doesn\'t work, you need to clean the paper pickup rollers at the front of the printer (where the paper first feeds into the machine. I use a Q-tip moistened (not sopping wet) with rubbing alcohol... gently scrub the whole pickup roller and then the feed roller next to it. Check carefully (with a flashlight) for any shards of paper that might be blocking the paper path. There is also a sensor flag (small finger of plastic) sticking up that the paper must hit to let the printer know that the paper is feeding through. If you do not see the sensor flag, it is either jammed or has been broken off when a piece of paper was pulled backward out of the paper feed area. First reload the printer driver, and try to print. If it doesn\'t print, check and clean the rollers and look for the sensor flag.
May 31, 2014 | HP 1050 Plain Paper Inkjet Fax
Konica Minolta Magicolor 2300W not transferring toner to paper.
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
Jan 28, 2013 | Minolta magicolor 2300W Laser Printer
When Copying or printing the paper does not feed
open the front cover pull out the cartridge and you see paper feed roller it is rubber. Clean paper feed roller with cloth and water or alcohol.
Jan 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Paper twisted while entering printer rollers and is jammed. How can I get it out?
Try to turn off the printer, open the compartment and check the roller. try to pull the paper and at the same time flip the roller in such a way that the paper will move out. If it is jammed and crumpled like what I exactly experienced earlier, remove the paper as fast as you can.
Turn on the printer, wait for the inkjet devices in a neutral position. Then insert the paper and start printing again. If it didn't work, try to hold the tip of the paper in horizontal manner while printing and make sure you remove the entire paper before the next page prints itself...
May 30, 2010 | HP DeskJet 940c InkJet Printer
Hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Jun 30, 2009 | HP LaserJet 1320 Printer
My HP PSC 1210 will not feed the paper through
Try removing the paper and replacing it with a heavier paper > pull out the 20# copy paper and replace it with 24# bond or 60# offset. ( The 24# and 60# are the same weight just different finishes on the surface ). Assuming your paper tray is one that slides in and out, close they tray firmly. Turn the printer off, wait 10 seconds then turn it back on. If the problem is still there, look VERY closely at the edges of the feed tray / compartment. There will be a very thin wire that the paper will depress when it is loaded into the feeder. If that wire gets bent the paper may not reach it to depress it. The printer does not sense any paper if this happens. Bend the wire outward so the paper can depress the sensor switch. Hope this helps.
Mar 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Office Pro k550 not working
mostly there is paper stuck in the paper feed roller at the bottom of the printer remove the paper tray and look at the roller and if paper is jammed remove from rollers and reset the printer. this should solve your problem . bye hope it does
Mar 06, 2008 | HP OfficeJet Pro k550 Printer
Printing problem with MFC-665CW
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
Brother MFC-J470DW Inkjet Multifunction Printer - Color - Plain Paper Print - Desktop Copier/Fax/Printer/Scanner - 35 ppm Mono/27 ppm Color Print - 12 ppm Mono/10 ppm Color Print ISO - 12 ipm Mono/10 ipm Color Print ISO - 1200 x 6000 dpi Print cpm Mono/5 cpm Logo
89 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
