Question about Brother MFC-J470DW Inkjet All-In-One Printer, Copier, Scanner, Fax
How do i get to print my web stuff coz my brother MF-J470DW is sending blank papers without prints
Removing the paper tray and reinserting it
    Sergeant:
  • Brother Expert
  • 316 Answers
If you machine prints other things without problem, then you should be more specific about what web stuff you are trying to print. Often web based images are in frames or links, and these can be very difficult to access or print. You may need to download or screen-dump the content before trying to print it.
Posted on Dec 07, 2014
Soulvisitor
  • 1113 Answers
SOURCE: Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Posted on Oct 28, 2007
SOURCE: brother HL-2040 laser printer
brother laserjet HL2040 printer
tonner error / paper error / continued rolling
what is the problem
Posted on Jan 02, 2009
  • 41 Answers
SOURCE: brother mfc-490cw won't print. sounds like it's
Does the Brother have a print utility, verifying cartridge levels?
You said you printed 40 pages?
Was there a lot of coverage per page?
You know that ALL printers only ship with STARTER cartridges, might want to check that first.
Does it not print black or color also?
Posted on Dec 01, 2009
pineworks
  • 4041 Answers
SOURCE: unable to print 51 - what doe it mean?
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Posted on Mar 11, 2010
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Help! I own a Epson 800 Artisan All-In-One. It keeps telling me that,"The paper tray is not seated correctly. Check for paper or objects blocking the cassette path. Reinsert the cassette tray and...
Try removing the rear duplexer unit and see if there may be something in the way. You will be able to see if the tray is flush to the end.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 15, 2017 | Epson Artisan 800 All-In-One InkJet...
Why does the orange light come on and off when I turn my printer on. It will not print. Thanks for helping this SENIOR out.
Check back cover is fastened on properly. Reinsert the back cover and turn the knob to the "lock" position. If that does not work then try removing paper and re-inserting. Remove paper tray and re-insert.
May 30, 2010 | HP Deskjet D4160 InkJet Photo Printer
Have a canon mp 470 keeps having a error of load paper in tray and it is full
Try removing the tray, reloading with the paper and reinserting the tray into the computer. If the paper is loaded a little unevenly, or if the tray is not fully inserted - or if there is an obstruction in the tray tracks, it would give you that error.
Oct 11, 2009 | Office Equipment & Supplies
Printer wont feed paper into the printer
remove the cables
remove the tray
wipe the rubber rolloers
with a moisten piece of cloth, to get back its picking ability
reinsert tray, make sure paper inside is shiny side up
reinsert power cable
try to print
hope it works, good luck
Sep 23, 2009 | Kodak EasyShare Thermal Photo Printer
Printer starts to print but then stops
try cleaning the rubber roller that picks up the paper from the tray with aocohol
Apr 13, 2009 | Samsung CLP 300 Laser Printer
No print catridge
The solution above worked on my printer, without power cycling.
1. Remove all paper from the input tray.
2. Open and close the door.
3. Reinsert the paper into the input tray.
Thanks,
Ilyas
Nov 14, 2007 | HP LaserJet 3050 All-In-One Printer
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Brother MFC-J470DW Inkjet All-In-One Printer, Copier, Scanner, Fax Logo
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
