Question about Frigidaire Refrigerators
How do I replace the defrost timer on frigidaire model ffph31m6l?
Turning it off for 24 hrs
  • Official Brand Answer
  • 2,267 Answers
Hello David Perry, thank you for your post!
I understand that you would like to change the defrost timer inside of your Frigidaire refrigerator, FFPH31M6L. Regrettably, this is not a simple DIY job. In order to accurately remove the old component and install the new timer I would recommend having a professional technician come out. This can help to avoid any personal injuries or future failure. Hope this information is helpful. -Matt
Posted on Dec 06, 2014
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
  • 531 Answers
SOURCE: defrost timer location
the timer in the refrigerator console were the control is
Posted on Apr 03, 2009
Maytag317
  • 1136 Answers
SOURCE: INSTALATION OF MAYTAG DEFROSTER TIMER
Hi, Here is a picture of the control panel where the timer is located. There is a1/4" screw holding the control panel up. Remove the screw and the control panel should release. The timer has a wire harness of 4 wires. It can only plug in 1 way.
Please let me know if this has helpes you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 26, 2009
VtToolMan
  • 704 Answers
SOURCE: where is defrost timer located on frigidaire
I couldn't pull up a line drawing for this model, but I recall that on these, (and other fridges of this age and era) had the defrost timer mounted under the front edge of the fridge, just behing the toe kick panel.
Some manufacturers mounted them at the rear behind the thin paperboard "cover", but I'd look for it at the front first.
In either location, it should be mounted behind a metal plate with a small hole in it that has a plastic or metal adjustment shaft that a flat bladed screwdriver slips into to manually advance the cycles.
Just remember to unplug the fridge before you disconnect the timer or attempt to replace it. Once you're done, you can advance the timer to initiate the defrost or cooling cycle, to gets things going.
Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
Fridge freezer stoping after 24 hrs
most of these freezers have an automatic defrost cycle.
after so many hours of chilling it will stop and run a de-icing cycle.
this is accomplished by one or two heating elements.
if one of the elements is burned out it will not run the defrost cycle.
and will ice up quickly.
depending on the model the heaters will usually cost about 15 to 20 dollars and they are easy to replace.
look up the model of your freezer and download the pdf files they will usually have a pictorial diagram showing the location
a defrost timer usually does nt fail on them unless it is physically damaged.
Aug 31, 2013 | Freezers
I have a Frigidaire FRT 22RRH. The coils keep freezing over and I have to manually defrost them. Where do I start to diagnose this issue.
It either the defrost timer or the heater, find the timer and if its turning very slowly like one rev. per. 9 hrs or so and continues thru its cycle the heater is bad, if you turn the timer to a defrost cycle and it stays there its bad.
Jun 30, 2011 | Refrigerators
Our Sharp refrigerator model SJ-F60PC. 4 doors, freezer at the bottom and fridge at top. The fridge section is not cold although the freezer section is working fine. Much appreciated if anyone can help!
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | Refrigerators
The bottom is not cooling, the freezer is cold. There doesn't seem to be any air flowing into the bottom portion
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the make model and year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Stopped cooling. fan still runs. after several hours started cooling good again.next morning stopped cooling again
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the model and year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | Whirlpool Refrigerators
Frigidaire Model FRT18DRH i have replaced the defrost timer and jumped the temp control and compressor still won't come on,had the compressor checked out and there is no problem there....am i missing...
Did you have them to check the freon gas pressure. The defrost timer could be bad that you replaced. Try turning the knob on the timer to see if the frig will kick the compressor on.
Dec 15, 2009 | Refrigerators
Kenmore Refg Displays DH on the screen after 24 hrs, is that a defrost problem
DH = Defrost Heater.
Kudos to kenmore for making an error message that makes sense.
Since the defroster timer turns on the defroster heater once every 24 hours, this makes sense.
Oct 21, 2009 | Kenmore Refrigerators
Frigidaire Fridge/freezer works then doesn't work???
every 6-8 hrs your ref. goes into a defrost mode. sounds to me like your fridge is getting stuck in defrost, may want to replace defrost timer roughly 18-45.00 dollars depending were you live. also ive seen a few that the electrical cord in back were it goes into ref mid way up to the left behind cover can have some loose connections back their; remove panel covering and inspect. becuz if its the timer it wouldnt cause the light not to work so it may not be your timer if the light it turning off.also make sure your outlet is good and the prongs on power cord are not loose. hope this helps
Sep 23, 2009 | Frigidaire Freezers
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidaire Gallery FRS26ZGEB - 12 years old
you have a defrost problem or damper problem or evapator fan
1) Check the fan in the freezer is running
2) defrost the freezer (leave unpluged with door open for 24 to 48 hrs or untill it stops leaking water...
3) check the damper make sure it is opening and cold air is blowing
How you need to repair what defrost part failed
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Jul 03, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
