Question about Valco Baby Matrix Stroller In Black
<!-- from fixya rte -->Take the tyre off to repair a puncture? - Valco Baby Matrix Stroller In Black
Where can I find the full service manual for Bmw x1 2011? Brake pad, disc replacement, suspension, steering system alignment and balancing etc... Also how to repair the punctured run flat tyre on Bmw x1???
Take the flat tyre to a tyre shop and have it repaired there as believe or not , puncture repair requires the correct tools and procedure for safety. As for the rest a good workshop manual should have that information or get a service hand book from the dealer service centre.
May 23, 2014 | Cars & Trucks
Adjust tyre beading
You may have broken the bead when you rode it while the tire was flat. More than likely you will need a new tire
Jun 10, 2013 | 2011 Hero Honda Passion Pro
Change wheels on my Capo or more resilient tyres, to reduce punctures.
I thing you shud keep the tyres and avoid pit falls
Apr 22, 2012 | Cannondale Capo
Can i change my pulsar 150 2003 to alloy wheels with tubles tyre and what is the advantage after changing this
That sounds like a lot of work and expense, if alloy wheels are available. Unless you have some alloy wheels of another bike and the axles, sprocket and brakes are compatible.
There is no real advantage, apart from tubless tyres can sometimes have punctures repaired without removing the tyres from the rims.
If punctures are a worry, then fit heavy duty inner tubes, which will last for years
Feb 25, 2011 | Bajaj Pulsar 150 Motorcycles
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
How do you fix a flat tyre on a maxi cosi mura?
If you have a puncture and there is only one hole, you can get a puncture repair kit for bikes from somewhere like Halfords and repair the inner tube.
I found the inner tube on one of our tyres was faulty and there were about 20 small holes around the seam. I got a bit fed up with arguing whether or not the guarantee should cover this and so we ended up buying a new inner tube from our local tyre place http://www.etbtyres.co.uk/ it was only £5.
Sep 28, 2009 | Maxi-Cosi Baby Gear
I need a new tube for a quinny buzz tyre
I had the same problem after getting a puncture racing around the centre MK. I got a new inner tube from my local Halfords store, it cost about £4.50 and then got some tyre Slime to puncture proof all three tyres! No punctures since!!
Dec 02, 2008 | Quinny Buzz Jogger
Flat left rear tyre - Jane power twin
think you have a puncture! tyre slime works wonders, i got a puncture on way home from school and used this repair system. worked a treat and treated all other tyres as a preventative measure. jope this helps
Nov 03, 2008 | Jane Powertwin Azulon Stroller
Flat tyre
We've just had same problem with a drawing pin. The tyres have an inner tube (like a bicycle tyre) which you can fix with a puncture repair kit- just find your local bicycle shop or somewhere like Halfords for this. Good luck!
Apr 25, 2008 | Quinny Buzz Jogger
Valco Baby Matrix Stroller In Black Logo
Top Valco Baby Baby Gear Experts
Dorel UK
Dorel UK
Are you a Valco Baby Baby Gear Expert? Answer questions, earn points and help others
